LAN transmit clock jitter spec
‎01-25-2022
08:32 PM
jautry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Is there a spec value for the amount of jitter to be expected on the MAC transmit clock output set to run at 50mhz. This is for the iMXRT1060 proc. I could not find it in the electrical specs.
‎02-09-2022
08:34 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The RT1060 datasheet does not provide related Ethernet output Reference clock jitter info.
While, the RT1060 EVK board connects external ENET PHY KSZ8081RNB chip has input clock request: 50MHz with ±50 ppm. The RT1060 EVK board Ethernet feature works robust & stable and related ouput clock quality should match with KSZ8081RNB request.
Thanks for the attention.
best regards,
Mike
