ImxRT 1176 LPSPI blocking function issue
1,420 次查看
chandan_uv
Hello, I’m working with LPSPI and using LPSPI_MasterTransferBlocking. Since this is a blocking function, I expect the LPSPI peripheral to be free once the transfer is complete. However, I observed something different.
After the blocking transfer, I read the SR (Status Register) using LPSPI_GetStatusFlags, and the returned value was 0x1001101.
Do you have any suggestions? Ideally, after the blocking transfer, the LPSPI should be idle. I’m sharing a code snapshot below for reference.
    if((staus_flag & kLPSPI_ModuleBusyFlag) == kLPSPI_ModuleBusyFlag)
        ret = STATUS_BUSY;
        PRINTF("SPI Busy, %x, %d\r\n", staus_flag, count);
    else
        masterXfer.txData   = SpiTxData;
        masterXfer.rxData   = SpiRxData;
        masterXfer.dataSize = spiTransferSize;
        masterXfer.configFlags =
        kLPSPI_MasterPcs0 | kLPSPI_MasterPcsContinuous;
        status = LPSPI_MasterTransferBlocking(LPSPI1, &masterXfer);
        ret = STATUS_SUCCESS;
        staus_flag = LPSPI_GetStatusFlags(IMU_SPI_IF);
        PRINTF("staus_flag: %x\r\n", staus_flag);
        count++;
        //sw_asm_delay_us(2U);
1,378 次查看
mayliu1
Hi @chandan_uv ,
Thank you so much for your interest in our products and for using our community.
Question:
Answer: I check your LPSPI SR register value is 0x1001101,
that is 0b0001 0000 0000 0001 0001 0000 0001, the TCF (Transfer Complete Flag) is 0,which means Transfer  Not complete.
From IMXRT1170RM,  we can see the detail SR status TCF  description. In Master mode, indicates that all transfers have completed and that LPSPI has returned to Idle state and the transmit FIFO is empty.
Question:
Answer:
I suggest you can develop your project based on SDK demo.
Please Verify the frame format configuration:
Make sure that the LPSPI settings (For example: Data Length, CPOL, CPHA) of the master device are exactly same to the slave device.
Wish it helps you.
Wish you a nice day!
Best Regards
MayLiu
1,379 次查看
mayliu1
Hi @chandan_uv ,
Question:
Question:
Answer:
Wish it helps you.
Best Regards
MayLiu
1,417 次查看
chandan_uv
BTW LPSPI1 and IMU_SPI_IF is same.
%3CLINGO-SUB%20id%3D%22lingo-sub-2086405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EImxRT%201176%20LPSPI%E9%98%BB%E5%A1%9E%E5%8A%9F%E8%83%BD%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2086405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20LPSPI%20%E5%B9%B6%E4%BD%BF%E7%94%A8%20LPSPI_MasterTransferBlocking%E3%80%82%E7%94%B1%E4%BA%8E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%98%BB%E5%A1%9E%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E4%B8%80%E6%97%A6%E4%BC%A0%E8%BE%93%E5%AE%8C%E6%88%90%EF%BC%8CLPSPI%20%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E5%B0%B1%E4%BC%9A%E7%A9%BA%E9%97%B2%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E4%B8%8D%E5%90%8C%E7%9A%84%E4%B8%9C%E8%A5%BF%E3%80%82%3C%2FP%3E%3CP%3E%E9%98%BB%E5%A1%9E%E4%BC%A0%E8%BE%93%E5%90%8E%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8LPSPI_GetStatusFlags%E8%AF%BB%E5%8F%96SR%EF%BC%88%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%89%EF%BC%8C%E8%BF%94%E5%9B%9E%E5%80%BC%E4%B8%BA0x1001101%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%E7%90%86%E6%83%B3%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E9%98%BB%E5%A1%9E%E4%BC%A0%E8%BE%93%E4%B9%8B%E5%90%8E%EF%BC%8CLPSPI%20%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E3%80%82%E6%88%91%E5%9C%A8%E4%B8%8B%E9%9D%A2%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%AA%E4%BB%A3%E7%A0%81%E5%BF%AB%E7%85%A7%E4%BB%A5%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20if((staus_flag%20%26amp%3B%20kLPSPI_ModuleBusyFlag)%20%3D%3D%20kLPSPI_ModuleBusyFlag)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20ret%20%3D%20STATUS_BUSY%3B%0A%20%20%20%20%20%20%20%20PRINTF(%22SPI%20Busy%2C%20%25x%2C%20%25d%5Cr%5Cn%22%2C%20staus_flag%2C%20count)%3B%0A%20%20%20%20%7D%0A%20%20%20%20else%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20masterXfer.txData%20%20%20%3D%20SpiTxData%3B%0A%20%20%20%20%20%20%20%20masterXfer.rxData%20%20%20%3D%20SpiRxData%3B%0A%20%20%20%20%20%20%20%20masterXfer.dataSize%20%3D%20spiTransferSize%3B%0A%20%20%20%20%20%20%20%20masterXfer.configFlags%20%3D%0A%20%20%20%20%20%20%20%20kLPSPI_MasterPcs0%20%7C%20kLPSPI_MasterPcsContinuous%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20LPSPI_MasterTransferBlocking(LPSPI1%2C%20%26amp%3BmasterXfer)%3B%0A%20%20%20%20%20%20%20%20ret%20%3D%20STATUS_SUCCESS%3B%0A%20%20%20%20%20%20%20%20staus_flag%20%3D%20LPSPI_GetStatusFlags(IMU_SPI_IF)%3B%0A%20%20%20%20%20%20%20%20PRINTF(%22staus_flag%3A%20%25x%5Cr%5Cn%22%2C%20staus_flag)%3B%0A%20%20%20%20%20%20%20%20count%2B%2B%3B%0A%20%20%20%20%20%20%20%20%2F%2Fsw_asm_delay_us(2U)%3B%0A%20%20%20%20%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2086408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AImxRT%201176%20LPSPI%20%E9%98%BB%E5%A1%9E%E5%8A%9F%E8%83%BD%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2086408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8CLPSPI1%20%E5%92%8C%20IMU_SPI_IF%20%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
