IMXRT1176 MIPI-CSI2RX Issue
1,059件の閲覧回数
burhanhagi
Contributor V
Hi NXP!
Will you give any reply to the questions? I am still waiting.
I want to know if IMXRT1176 supports or not ITU-R.BT656 format over MIPI-CSI2 peripheral/bus. Do I have to use parallel CSI interface instead?
IMXRT1176 MIPI_CSI2RX not run
does imxrt1170 MIPI-CSI2 peripheral support serial itu-r.bt656 format?
Is there any errata regarding MIPI_CSI2 RX Controller supported data format?
IMXRT1176 MIPI CSI2 Peripheral one-bit error and two bit error not set
0 返答(返信)
