IMXRT1064 ENET Send Problem
Lukas_Frank
Senior Contributor I
I am trying to communicate two 1064 EVK via Ethernet Port. Firstly, I decided to use enet_txrx_transfer SDK example.
Packets are not transmitting from EVK_A to EVK_B.
Please look details from here : IMXRT1064-ENET-Transfer-between-EVKs
 Could you please help me what is wrong?
Thanks and Regards.
kerryzhou
Hi @Lukas_Frank ,
   I reply you in your old post:
https://community.nxp.com/t5/i-MX-RT/IMXRT1064-ENET-Transfer-between-EVKs/m-p/1444106
Do you check the related code, it can work for the two board communication.Please check the application note I tell you.
Kerry
kerryzhou
Hi @Lukas_Frank ,
Kerry
