IAR startup source code
2,273 次查看
g_volokh
Hi, All.
I see  the startup codes only for GCC in SDK, but I am working with IAR.
Where can I find IAR source code or I should to create it myself?
Thanks in advance.
George.
标签 (4)
2,214 次查看
jingpan
Hi George,
When you download SDK and select toolchain, add IAR or select all toolchains. Then you will see IAR examples. You can use their startup code.
Jing
2,214 次查看
g_volokh
Dear Jing,
Thanks a lot, it was very helpful.
George Volokh.
