I'm using the USB host of RT1060. Actually, I'm not familiar with USB host behavior. When data communication occurred error, I try to set the port reset bit of USB_nPORTSC1 register to re-enumerate the USB device again. From the USB packet sniffer (as attachment), the USB host controller sending the J-state packet but does not issue any Get_Descriptor command. Does any step I miss during the process?
