How to Read the data From Sensor Through SPI Protocol.
1,390件の閲覧回数
SudarshanSingathala
How to read the data from a sensor(Accelerometer) Through SPI protocol in MCU Xpresso IDE. Which API need use to read the data. Kindly help me with an example.
Sudarshan.
1,372件の閲覧回数
gusarambula
Hello Sudarshan,
A good starting points would be the SDK for the i.MXRT board you are using and it’s documentation. There are some examples that can be run to test the SPI module. You may download the SDK for your board on the link below or directly from within MCUXpresso IDE.
https://mcuxpresso.nxp.com/en/select
I hope that this information helps!
Gustavo
