How can I debug a Zephyr multi-core project on i.MXRT1165?
tringuyenbk06
Hi everyone,
I am working on a simple dual-core application (referring to the IPC sample on the EVK and just printing logs from both cores over UART) using an MXRT-1165 custom board with the Zephyr project. I can flash both core images using J-Link Flash, but it is not working (no logs are received).
Question: How can I use MCUXpresso IDE to load both ELF files to debug the multi-core project?
zephyr.elf
zephyr.elf
Note: Our NOR Flash uses the 2nd pin mux (non-default) on FlexSPI1.
Thank you in advance!
tringuyenbk06
Hi @Gavin_Jia
Thank you for your respond.
I am asking if MCUXpresso IDE support a debug only project mode where I can load 2 elf files for dual core debugging.
i.MX RT1170 Dual Core Application
Tri Nguyen
tringuyenbk06
Hi @Gavin_Jia
The zephyr sample mentions log check/debug only.
I am asking if IMCUXpresso IDE can support a multi core debug project where I can load dual core elf files on the board.
Tri Nguyen
Gavin_Jia
Hi @tringuyenbk06 ,
Thank you for your clarification!
However, to my knowledge, there is no out-of-the-box dual-core Zephyr ELF debug-only example provided in MCUXpresso IDE. Customers may need to debug both projects in RAM separately, pass the tests, and then attempt to use CM7 load the CM4 image into OCRAM before kicking CM4.
For the Zephyr project, NXP provides the official compilation and debugging environment MCUXpresso for VS Code, which you may also try.
Gavin
tringuyenbk06
Thank you for your assistance.
I will give it a try with the EVK first.
tringuyenbk06
I correct the elf file paths mentioned in the ticket description.
build\cm7\zephyr\zephyr.elf
build\cm4\zephyr\zephyr.elf
tringuyenbk06
Gavin_Jia
Hi @tringuyenbk06 ,
Thanks for your interest in NXP MIMXRT series!
Currently, there is only one example of a similar implementation. Please refer to the steps in this guide: https://docs.zephyrproject.org/latest/boards/nxp/mimxrt1170_evk/doc/index.html
We apologize for any inconvenience this may cause!
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2326736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FP%3E%3CP%3EHi%20everyone%2C%3C%2FP%3E%3CP%3EI%20am%20working%20on%20a%20simple%20dual-core%20application%20(referring%20to%20the%20IPC%20sample%20on%20the%20EVK%20and%20just%20printing%20logs%20from%20both%20cores%20over%20UART)%20using%20an%20MXRT-1165%20custom%20board%20with%20the%20Zephyr%20project.%20I%20can%20flash%20both%20core%20images%20using%20J-Link%20Flash%2C%20but%20it%20is%20not%20working%20(no%20logs%20are%20received).%3C%2FP%3E%3CP%3EQuestion%3A%20How%20can%20I%20use%20MCUXpresso%20IDE%20to%20load%20both%20ELF%20files%20to%20debug%20the%20multi-core%20project%3F%3C%2FP%3E%3CP%3Ezephyr.elf%3CBR%20%2F%3Ezephyr.elf%3CBR%20%2F%3ENote%3A%20Our%20NOR%20Flash%20uses%20the%202nd%20pin%20mux%20(non-default)%20on%20FlexSPI1.%3C%2FP%3E%3CP%3EThank%20you%20in%20advance!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203261%22%20target%3D%22_blank%22%3E%40Gavin_Jia%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20for%20your%20respond.%3CBR%20%2F%3EI%20am%20asking%20if%26nbsp%3BMCUXpresso%20IDE%20support%20a%20debug%20only%20project%20mode%20where%20I%20can%20load%202%20elf%20files%20for%20dual%20core%20debugging.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13264.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20RT1170%20Dual%20Core%20Application%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3ETri%20Nguyen%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203261%22%20target%3D%22_blank%22%3E%40Gavin_Jia%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20for%20your%20respond.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20zephyr%20sample%20mentions%20log%20check%2Fdebug%20only.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20asking%20if%20IMCUXpresso%20IDE%20can%20support%20a%20multi%20core%20debug%20project%20where%20I%20can%20load%20dual%20core%20elf%20files%20on%20the%20board.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13264.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20RT1170%20Dual%20Core%20Application%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3ETri%20Nguyen%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206143%22%20target%3D%22_blank%22%3E%40tringuyenbk06%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20interest%20in%20NXP%20MIMXRT%20series!%3C%2FP%3E%0A%3CP%3ECurrently%2C%20there%20is%20only%20one%20example%20of%20a%20similar%20implementation.%20Please%20refer%20to%20the%20steps%20in%20this%20guide%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fdocs.zephyrproject.org%2Flatest%2Fboards%2Fnxp%2Fmimxrt1170_evk%2Fdoc%2Findex.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.zephyrproject.org%2Flatest%2Fboards%2Fnxp%2Fmimxrt1170_evk%2Fdoc%2Findex.html%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EWe%20apologize%20for%20any%20inconvenience%20this%20may%20cause!%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorGavin_Jia_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20correct%20the%20elf%20file%20paths%20mentioned%20in%20the%20ticket%20description.%3CBR%20%2F%3Ebuild%5Ccm7%5Czephyr%5Czephyr.elf%3CBR%20%2F%3Ebuild%5Ccm4%5Czephyr%5Czephyr.elf%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206143%22%20target%3D%22_blank%22%3E%40tringuyenbk06%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20clarification!%3C%2FP%3E%0A%3CP%3EHowever%2C%20to%20my%20knowledge%2C%20there%20is%20no%20out-of-the-box%20dual-core%20Zephyr%20ELF%20debug-only%20example%20provided%20in%20MCUXpresso%20IDE.%20Customers%20may%20need%20to%20debug%20both%20projects%20in%20RAM%20separately%2C%20pass%20the%20tests%2C%20and%20then%20attempt%20to%20use%20CM7%20load%20the%20CM4%20image%20into%20OCRAM%20before%20kicking%20CM4.%3C%2FP%3E%0A%3CP%3EFor%20the%20Zephyr%20project%2C%20NXP%20provides%20the%20official%20compilation%20and%20debugging%20environment%20MCUXpresso%20for%20VS%20Code%2C%20which%20you%20may%20also%20try.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2334350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20can%20I%20debug%20a%20Zephyr%20multi-core%20project%20on%20i.MXRT1165%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2334350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20assistance.%3CBR%20%2F%3EI%20will%20give%20it%20a%20try%20with%20the%20EVK%20first.%3C%2FLINGO-BODY%3E
