Have any tool measure function 's time execution and power consumer on MXRT-1050
phamvantien96
Hi everyone,
I want to measure the function 's time executed and power comsumer on i.MXRT-1050 Evaluation KIT. I search document and see the SWO Trace but I cant use that. Someone help me use that or suggest me some idea for measure them, i know i can use timer for measure time, but i search for some easier solution.
Thank you!
igorpadykov
Hi Pham
unfortunately such tools are not available, as estimation one can use
AN12094 Power consumption and measurement of i.MXRT1050
https://www.nxp.com/docs/en/application-note/AN12094.pdf
and sect.4.1.5 Maximum supply currents i.MXRT1050 Datasheet
https://www.nxp.com/docs/en/data-sheet/IMXRT1050CEC.pdf
