EVSE Setup
EVSE Setup
4,981 次查看
Bay
Hi, I have issue with the EVSE Setup. Keep disconnected from IoTHub. May I know how to solve this?
标签 (1)
8 回复数
4,840 次查看
kerryzhou
Hi @Bay ,
  Any updated information about your issues?
  Do you still have question about it?
  We highly recommend you create question post in our solution community, then our expert will help you directly:
https://community.nxp.com/t5/Power-Energy/bd-p/Power-and-Energy
Kerry
4,838 次查看
Bay
Hi Kerry, the issue still there.
I have created the question in this link: how to use the EVSE setup without SE050 - NXP Community.
Thanks.
4,835 次查看
kerryzhou
Hi @Bay ,
Thanks so much!
I will let one of our solution colleague help you step by step.
As we already tested both with SE050 and without SE050 on my platform, all works Ok.
We will reply you in your community post directly, thanks.
Kerry
4,943 次查看
kerryzhou
Hi @Bay ,
    Thanks so much for using the NXP solution platform, I would like to provide service for you.
   Do you use this platform:
https://www.nxp.com/design/designs/easyevse-ev-charging-station-development-platform-mcu-rtos:CONNEC...
When you connect the cloud to the Azure cloud meet the issues?
Do you use the SE050 secure or not? If you use the SE050, you also need to upload your SE050 related provisioning to the cloud, I think, you also can try to without the SE050, it may make things easy.
I mean like this:
If still have issues, tell me your detail steps about the cloud configuration, and the code configuration, and also some video about your platform, it will helps to identify the root issues, thanks.
kerry
4,932 次查看
Bay
Hi, Yes I am using that platform.
I have created the certificate using SE050 and upload to cloud.
Here is the output terminal:
4,918 次查看
kerryzhou
Hi @Bay ,
  Thanks for your information.
 Do you also try the method without the SE050, whether that works or not?
 I just want to check, whether your network side is working OK, not from the secure side.
  Please also help to check the method without the SE050, thanks.
Any updated information, please kindly let me know.
Kerry
4,909 次查看
Bay
What should I do to test without SE050?
Is it change the code? Or just remove the Se050 from the setup?
4,903 次查看
kerryzhou
Hi @Bay ,
  Good question!
  In fact, in my first reply to you, already give you the code modification details for the none SE050 method.
  We also have the detail steps include the clould method.
  Now, good news, we already launch the solution community, this is for the solution professional support!
  Please help to create a new questions post about how to use the EVSE setup without SE050, then I will tell one of my solution colleague help you step by step.
  Please create the new question post in this community:
  Then, share your link here, thanks.
Wish it helps you!
Kerry
