Creating a binary image for sln-local2-iot sdk
jnj
Hi All,
How can we create a complete binary image including bootloader(Both bank A and B) and application for sln-local2-iot?Is there any tool to generate a complete bin image ?If yes kindly share the same.
Thanks in advance.
kerryzhou
Hi @jnj ,
   Yes, we have tool can help you download all the code:bootstrap, bootloader, local_demo, audio playback files, and FICA table.
Please refer to the design guider:
https://www.nxp.com/webapp/Download?colCode=SLN-LOCAL2-IOT-DG
Chapter 11 Automated manufacturing tools
The tool link is:
https://www.nxp.com/webapp/Download?colCode=Ivaldi_sln_local2_iot&appType=license&location=null
The app should be bankA, when you want to run bank B, you can use the MSD method to update the app directly.
Wish it helps you!
Kerry
jnj
Hi @kerryzhou ,
Thank you for the response.I will check and get back to you.
kerryzhou
OK, totally follow the document, you will make it success.
Kerry
