CAAM_CRC_Update issue
1,137 次查看
vishnuprasadv
We are trying to use CAM module in MIMXRT1176DVMAA and for that took example code from SDK_2_14_0_MIMXRT1170-EVKB version. But we are successfully execute the sample code it fails in Cam wait() function. Please find the attached log and code kindly provide the solution for CAM module CRC usage.
Fail log:
*CAAM Job Ring 0* :
CRC: before wait
status 1
- failed to CRC update status 1 !
- failed to deinit RNG!
1 回复
1,098 次查看
Omar_Anguiano
Hello
I hope you are well.
I was able to run the SDK example successfully delimiting it to only do CRC operation. I suggest you check the memory settings of your project on where some variables are placed.
Omar
