24MHz Crystal Load Capacitance Value in RT105x
deega_jung
The Load Capacitance value of the 24 MHz crystal is not verified in the RT105x documents.
Please let me know the Load Capacitance Value of 24 MHz crystal.
Deega
deega_jung
Hi Kerry,
Thank you for your reply.
Deega
deega_jung
Hi Kerry,
Deega
kerryzhou
Hi @deega_jung ï¼Œ
   Normally, the 24Mhz crystal loader capacitor data is determined by your selected crystal datasheet, you can check your crystal datasheet, it will contains the recommend loader capacitor. in the practical customer board, choose the crystal datasheet data, then associated with the actual PCB layout to tune the load capacitor to meet the crystal PPM. This data didn't determined by the MCU RT chip.
   Wish it helps you!
kerry
