Recovery Methods for RT595 and RT685 Development Boards When Programming Fails
During the development and use of RT595 and RT685 development boards, developers often encounter a common issue reported by users: persistent errors during programming via a debugger, making it impossible to reprogram the board and effectively rendering it “bricked.” These issues can arise from various causes, such as incorrect FCB writing, interruptions during the download process, or other unknown anomalies.
This article introduces two effective recovery methods:
  1. Using the SEC TOOL utility.
  2. Using an external J-Link programmer.
Note: Both methods require setting the RT595 and RT685 boards to Serial ISP mode beforehand. NXP has released two RT685-based development boards (MIMXRT685-AUD-EVK and MIMXRT685-EVK) and one RT595 board. Since the RT595 board operates similarly to the RT685 boards, this article uses the MIMXRT685-AUD-EVK board for demonstration. Ensure the SDK version is correct during the process.
1. Preparation: Entering Serial ISP Mode
Using the MIMXRT685-AUD-EVK board as an example, set switches SW5[1-3] to “ON OFF OFF” to enter Serial ISP mode. This corresponds to the following pin levels:
  • PIO1_17: High
  • PIO1_16: High
  • PIO1_15: Low
Refer to the RT600 User Manual for detailed mappings between ISP pins and boot modes.
mayliu1_2-1760596693245.pngmayliu1_2-1760596693245.pngmayliu1_3-1760596700476.pngmayliu1_3-1760596700476.png
2. Method 1: Recovery Using SEC TOOL
1. Preparation: Generate APP Image
  • Import SDK Demo: Open MCUXpresso IDE and import the demo project mimxrt685audevk_lpc_gpio_led_output_cm33.
  • Modify Project Settings: Make two key configuration changes to ensure successful image generation.
  • mayliu1_5-1760596800335.pngmayliu1_5-1760596800335.pngmayliu1_6-1760596804637.pngmayliu1_6-1760596804637.png
  • Generate Hex File: After configuration, build the project to generate a Hex file for use with SEC TOOL.
2. Using SEC TOOL
mayliu1_8-1760596890883.pngmayliu1_8-1760596890883.pngmayliu1_9-1760596894590.pngmayliu1_9-1760596894590.png
  • Configure Flash Type and Test: Select the default external NOR Flash for MIMXRT685-AUD-EVK, apply settings, and run a test.
  • Build Image: Use the previously generated App image and click “Build Image.”
  • Program Image: Flash the image to the RT685 chip.
  • Switch Boot Mode: Power off the board and set Boot mode to FlexSPI Boot from PortB:
    • PIO1_17: Low
    • PIO1_16: High
    • PIO1_15: Low
    • SW5[1-3]: “ON OFF ON”
Power on the board again. It should now operate normally and run the program successfully.
3. Method 2: Recovery Using J-Link Programmer
1. Preparation: Generate Flashable File
  • Import the same demo project into MCUXpresso IDE and compile it without modifications to generate a Hex or S19 file.
  • Download and install SEGGER J-Flash from SEGGER Official Website.
2. Hardware Setup
  • Board Modifications:
    • Connect pins 2 and 3 of JP2.
    • Remove jumpers JP17, JP18, JP19 (ensure p3 is disconnected).
    • Set SW5 to “ON OFF OFF”.
  • Device Connection:
    • Connect J-Link Plus to J19 on the board.
    • Connect J6 to the PC to power the board.
3. Programming with J-Flash
  • Create New Project: Open J-Flash and create a new project for MIMXRT685S. Note: RT685 supports only SWD, not JTAG.
mayliu1_14-1760597088841.pngmayliu1_14-1760597088841.pngmayliu1_15-1760597093145.pngmayliu1_15-1760597093145.png
  • Flash Program: Load the Hex file and flash it to the board.
  • Switch Boot Mode: After flashing, power off the board and set Boot mode to FlexSPI Boot from PortB:
    • PIO1_17: Low
    • PIO1_16: High
    • PIO1_15: Low
Power on the board again. It should now function normally and run the program successfully.
Conclusion
By following either of the two methods described above, developers can effectively recover RT595 and RT685 development boards from programming failures and restore normal operation. Choose the method that best suits your specific situation.
%3CLINGO-SUB%20id%3D%22lingo-sub-2187236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT595%E3%81%8A%E3%82%88%E3%81%B3RT685%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AE%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%3CSTRONG%3ERT595%E3%81%8A%E3%82%88%E3%81%B3RT685%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AE%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ERT595%E3%81%8A%E3%82%88%E3%81%B3RT685%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E4%B8%AD%E3%81%AB%E3%80%81%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8B%E3%82%89%E3%82%88%E3%81%8F%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%82%8B%E5%85%B1%E9%80%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E4%BB%8B%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81%E5%AE%9F%E8%B3%AA%E7%9A%84%E3%81%AB%E3%80%8C%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%E5%8C%96%E3%80%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%9FFCB%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E5%87%A6%E7%90%86%E4%B8%AD%E3%81%AE%E4%B8%AD%E6%96%AD%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E4%B8%8D%E6%98%8E%E3%81%AA%E7%95%B0%E5%B8%B8%E3%81%AA%E3%81%A9%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%8B%E3%82%89%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AE%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%E6%96%B9%E6%B3%95%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3ESEC%20TOOL%3C%2FSTRONG%3E%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%A4%96%E9%83%A8%E3%81%AE%3CSTRONG%3EJ-Link%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%82%E3%80%81%E4%BA%8B%E5%89%8D%E3%81%ABRT595%E3%81%8A%E3%82%88%E3%81%B3RT685%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%3CSTRONG%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%ABISP%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82NXP%E3%81%AF%E3%80%81RT685%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%9F2%E3%81%A4%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%88MIMXRT685-AUD-EVK%E3%81%A8MIMXRT685-EVK%EF%BC%89%E3%81%A8%E3%80%811%E3%81%A4%E3%81%AERT595%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82RT595%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFRT685%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AFMIMXRT685-AUD-EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%9C%E6%A5%AD%E4%B8%AD%E3%81%ABSDK%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_1-1760596577697.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_1-1760596577697.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361080i7F6BBA7B5C9A785C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_1-1760596577697.png%22%20alt%3D%22mayliu1_1-1760596577697.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_1-1760596577697.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CH3%20id%3D%22toc-hId-1976651960%22%20id%3D%22toc-hId-1998793580%22%3E1.%20%E6%BA%96%E5%82%99%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%ABISP%E3%83%A2%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%80%82%3C%2FH3%3E%0A%3CP%3EMIMXRT685-AUD-EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW5%5B1-3%5D%E3%82%92%E3%80%8CON%20OFF%20OFF%E3%80%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%ABISP%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%94%E3%83%B3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AB%E7%9B%B8%E5%BD%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EPIO1_17%EF%BC%9A%E9%AB%98%3C%2FLI%3E%0A%3CLI%3EPIO1_16%EF%BC%9A%E9%AB%98%3C%2FLI%3E%0A%3CLI%3EPIO1_15%EF%BC%9A%E4%BD%8E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EISP%E3%83%94%E3%83%B3%E3%81%A8%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81RT600%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_2-1760596693245.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_2-1760596693245.png%22%20style%3D%22width%3A%20333px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361081iA2DBE78A8AFE0D1E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_2-1760596693245.png%22%20alt%3D%22mayliu1_2-1760596693245.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_2-1760596693245.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_3-1760596700476.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_3-1760596700476.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361082iA9815124AD257B93%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_3-1760596700476.png%22%20alt%3D%22mayliu1_3-1760596700476.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_3-1760596700476.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CH3%20id%3D%22toc-hId-169197497%22%20id%3D%22toc-hId-191339117%22%3E2.%20%E6%96%B9%E6%B3%951%EF%BC%9ASEC%20TOOL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%26nbsp%3B%3C%2FH3%3E%0A%3CH4%20id%3D%22toc-hId-859758971%22%20id%3D%22toc-hId-881900591%22%3E1.%20%E6%BA%96%E5%82%99%EF%BC%9AAPP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3ESDK%E3%83%87%E3%83%A2%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%EF%BC%9AMCUXpresso%20IDE%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8Cmimxrt685audevk_lpc_gpio_led_output_cm33%E3%80%8D%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_4-1760596785475.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_4-1760596785475.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361083i6F0ABD94F0C03117%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_4-1760596785475.png%22%20alt%3D%22mayliu1_4-1760596785475.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_4-1760596785475.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSTRONG%3E%EF%BC%9A%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E7%94%9F%E6%88%90%E3%82%92%E6%88%90%E5%8A%9F%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E8%A8%AD%E5%AE%9A%E5%A4%89%E6%9B%B4%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_5-1760596800335.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_5-1760596800335.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361084iE2C32C3CA6DA6B87%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_5-1760596800335.png%22%20alt%3D%22mayliu1_5-1760596800335.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_5-1760596800335.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_6-1760596804637.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_6-1760596804637.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361085iF2A9E3FF6F856019%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_6-1760596804637.png%22%20alt%3D%22mayliu1_6-1760596804637.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_6-1760596804637.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EHex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E7%94%9F%E6%88%90%3C%2FSTRONG%3E%EF%BC%9A%E8%A8%AD%E5%AE%9A%E5%BE%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%80%81SEC%20TOOL%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BHex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_7-1760596831665.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_7-1760596831665.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361086iEBC527205ED4440B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_7-1760596831665.png%22%20alt%3D%22mayliu1_7-1760596831665.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_7-1760596831665.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CH4%20id%3D%22toc-hId--947695492%22%20id%3D%22toc-hId--925553872%22%3E2.%20SEC%20TOOL%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3ESEC%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FSTRONG%3E%3A%20SEC%20TOOL%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81MIMXRT685S%E7%94%A8%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E6%8E%A5%E7%B6%9A%E6%96%B9%E6%B3%95%E3%81%AE%E9%81%B8%E6%8A%9E%3C%2FSTRONG%3E%EF%BC%9ART500%E3%81%8A%E3%82%88%E3%81%B3RT600%E3%81%AFUSB%E3%80%81UART%E3%80%81SPI%E3%80%81I2C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E4%BE%8B%EF%BC%9AJ5%E7%B5%8C%E7%94%B1%E3%81%AEUART%E3%81%BE%E3%81%9F%E3%81%AFJ7%E7%B5%8C%E7%94%B1%E3%81%AEUSB%E3%81%AA%E3%81%A9%EF%BC%89%E3%80%82%E4%B8%80%E5%BA%A6%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AF1%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_8-1760596890883.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_8-1760596890883.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361088i9FDF520F6D00284E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_8-1760596890883.png%22%20alt%3D%22mayliu1_8-1760596890883.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_8-1760596890883.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_9-1760596894590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_9-1760596894590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361089i35D16A1C77FE857E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_9-1760596894590.png%22%20alt%3D%22mayliu1_9-1760596894590.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_9-1760596894590.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%BF%E3%82%A4%E3%83%97%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3A%20MIMXRT685-AUD-EVK%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%A4%96%E4%BB%98%E3%81%91NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_10-1760596916554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_10-1760596916554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361090i6F33D341D799F266%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_10-1760596916554.png%22%20alt%3D%22mayliu1_10-1760596916554.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_10-1760596916554.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSTRONG%3E%EF%BC%9A%E4%BB%A5%E5%89%8D%E3%81%AB%E7%94%9F%E6%88%90%E3%81%97%E3%81%9FAPP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%80%8CBuild%20Image%EF%BC%88%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_11-1760596979292.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_11-1760596979292.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361091iC7D8832EF5CC4738%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_11-1760596979292.png%22%20alt%3D%22mayliu1_11-1760596979292.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_11-1760596979292.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FSTRONG%3E%EF%BC%9A%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92RT685%E3%83%81%E3%83%83%E3%83%97%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_12-1760596995145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_12-1760596995145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361092i66B3B8FD71FF0D73%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_12-1760596995145.png%22%20alt%3D%22mayliu1_12-1760596995145.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_12-1760596995145.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSTRONG%3E%EF%BC%9A%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8A%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%3CSTRONG%3EFlexSPI%20Boot%20from%20PortB%EF%BC%88PortB%E3%81%8B%E3%82%89%E3%81%AEFlexSPI%20%E3%83%96%E3%83%BC%E3%83%88%EF%BC%89%3C%2FSTRONG%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%0A%3CUL%3E%0A%3CLI%3EPIO1_17%3A%20%E4%BD%8E%3C%2FLI%3E%0A%3CLI%3EPIO1_16%EF%BC%9A%E9%AB%98%3C%2FLI%3E%0A%3CLI%3EPIO1_15%EF%BC%9A%E4%BD%8E%3C%2FLI%3E%0A%3CLI%3ESW5%5B1-3%5D%EF%BC%9A%E3%80%8CON%20OFF%20ON%E3%80%8D%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%86%8D%E5%BA%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_13-1760597057591.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_13-1760597057591.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361093i7BE187CA12510F3F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_13-1760597057591.png%22%20alt%3D%22mayliu1_13-1760597057591.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_13-1760597057591.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CH3%20id%3D%22toc-hId--958198596%22%20id%3D%22toc-hId--936056976%22%3E3.%20%E6%96%B9%E6%B3%952%EF%BC%9AJ-Link%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%3C%2FH3%3E%0A%3CH4%20id%3D%22toc-hId--267637122%22%20id%3D%22toc-hId--245495502%22%3E1.%20%E6%BA%96%E5%82%99%EF%BC%9A%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%E5%90%8C%E3%81%98%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92MCUXpresso%20IDE%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9A%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%80%81Hex%E3%81%BE%E3%81%9F%E3%81%AFS19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3ESEGGER%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%3CSTRONG%3ESEGGER%20J-Flash%3C%2FSTRONG%3E%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH4%20id%3D%22toc-hId--2075091585%22%20id%3D%22toc-hId--2052949965%22%3E2.%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSTRONG%3E%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3EJP2%E3%81%AE%E3%83%94%E3%83%B32%E3%81%A83%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3EJP17%E3%80%81JP18%E3%80%81JP19%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88p3%E3%81%8C%E5%88%87%E6%96%AD%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3ESW5%E3%82%92%E3%80%8CON%20OFF%20OFF%E3%80%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%8E%A5%E7%B6%9A%EF%BC%9A%3C%2FSTRONG%3E%0A%3CUL%3E%0A%3CLI%3EJ-Link%20Plus%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEJ19%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3EJ6%E3%82%92PC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH4%20id%3D%22toc-hId-412421248%22%20id%3D%22toc-hId-434562868%22%3E3.%20J-Flash%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FSTRONG%3E%EF%BC%9AJ-Flash%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81MIMXRT685S%E7%94%A8%E3%81%AE%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%B3%A8%EF%BC%9ART685%E3%81%AFSWD%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81JTAG%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_14-1760597088841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_14-1760597088841.png%22%20style%3D%22width%3A%20387px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361094iA25436EE58678934%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_14-1760597088841.png%22%20alt%3D%22mayliu1_14-1760597088841.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_14-1760597088841.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_15-1760597093145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_15-1760597093145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361095i34348261DE044219%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_15-1760597093145.png%22%20alt%3D%22mayliu1_15-1760597093145.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_15-1760597093145.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FSTRONG%3E%EF%BC%9AHex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_16-1760597109388.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_16-1760597109388.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361096i0DFB2F181AE4BC9A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_16-1760597109388.png%22%20alt%3D%22mayliu1_16-1760597109388.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_16-1760597109388.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSTRONG%3E%EF%BC%9A%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8A%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%3CSTRONG%3EFlexSPI%20Boot%20from%20PortB%EF%BC%88PortB%E3%81%8B%E3%82%89%E3%81%AEFlexSPI%20%E3%83%96%E3%83%BC%E3%83%88%EF%BC%89%3C%2FSTRONG%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%0A%3CUL%3E%0A%3CLI%3EPIO1_17%3A%20%E4%BD%8E%3C%2FLI%3E%0A%3CLI%3EPIO1_16%EF%BC%9A%E9%AB%98%3C%2FLI%3E%0A%3CLI%3EPIO1_15%EF%BC%9A%E4%BD%8E%3C%2FLI%3E%0A%3CLI%3ESW5%5B1-3%5D%EF%BC%9A%E3%80%8CON%20OFF%20ON%E3%80%8D%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%86%8D%E5%BA%A6%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1760597371876.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1760597371876.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361101i24C03832A737FE20%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1760597371876.png%22%20alt%3D%22mayliu1_0-1760597371876.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emayliu1_0-1760597371876.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%81%BE%E3%81%A8%E3%82%81%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE2%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AFRT595%E3%81%A8RT685%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%8B%E3%82%89%E5%8A%B9%E6%9E%9C%E7%9A%84%E3%81%AB%E5%BE%A9%E6%97%A7%E3%81%97%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AA%E5%8B%95%E4%BD%9C%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%AB%E6%9C%80%E3%82%82%E9%81%A9%E3%81%97%E3%81%9F%E6%96%B9%E6%B3%95%E3%82%92%E3%81%8A%E9%81%B8%E3%81%B3%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2187236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%20RT600%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎10-15-2025 11:50 PM
更新者:
