xen and jailhouse virtualization
5,664 次查看
weideding
     I am using i.mx8mq, from recent its BSP, it only supports jailhouse, do you think it is possible to run Android inside it? I want to run yocto+android together over i.mx8mq.
    As I known i.mx8quadmax could run XEN, but  i.mx8mq cannot support XEN. Do you think it is possible to run XEN over i.mx8mq? If yes, our company may work on this.  the performance  will be very poor? Or Does NXP have some release plan to implement XEN over i.mx8m?
Thanks for your attentions!
8 回复数
4,664 次查看
muniasamy_ramar
Hi Joan,
 Do you have  any update to support  with Linux on XEN hypervisor for  i.MX 8QuadXPlus Multisensory Enablement Kit (MEK) .
标记 (1)
4,729 次查看
dhty2015
请问怎么在yocto编译中加入jailhouse?我在发布的文档上没有找到相应的描述
4,730 次查看
dhty2015
已经在4.14.98文档中找到。
4,730 次查看
weideding
Already got the answers, i.mx8m is possible to run Android inside jailhouse, but should take care of assigning hardware resources, such only have one GPU, VPU etc.
i.mx8m does not have SMMU like i.mx8quadmax, it is not good for XEN with using paradriver.
4,730 次查看
joanxie
yes, and we don't have plan to support virtualized Android using XEN or Jailhouse on i.MX8MQ currently
4,730 次查看
baodongchen
How about imx8qxp,  is it possible run android along with linux on top of xen?
I see 'domu-imx8qm-mek-androidauto.cfg' with device pass through feature, but for imx8qxp,  only 'domu-imx8qxp.cfg'.
imx-xen
4,730 次查看
joanxie
yes, we have this plan to run on the imx8qxp
4,730 次查看
longting_6
Hi Joan, about i.mx8qxp, is there any update to support android along with linux on xen currently? Thanks.
