weston
weston
1,390 次查看
gopal_rhsharma
I,m using
imx93evk-11x11
DISTRO=fsl-imx-xwayland MACHINE=imx93evk source imx-setup-release.sh -b build-xwayland
BSP 6.6.3
weston 12.0.3
facing problem to load wayland-backend.so
commands like
LayerManagerControl etc. not available please kindly help or suggest to resolving issue.
标记 (1)
2 回复数
1,371 次查看
Bio_TICFSL
You are playing with non-suppoted version and the galcore is passing as module you might try the 6.6.36 bsp.
1,363 次查看
gopal_rhsharma
our development is going on with BSP 6.6.3. any other method to resolve the problem Rather then to change the BSP.
thanks,
