Dear All,
Just wanted to check if the USB host stack available in MCUXpresso SDK supports 4G modem type devices. Also SFTP protocol as i don't see any SFTP protocol in lwip stack in the SDK.
Babu
Solved! Go to Solution.
Hi again @sbabu,
I believe this Application Note will be useful for your inquiry: https://www.nxp.com/docs/en/application-note/AN13940.pdf
Hi @sbabu,
The SFTP protocol is not supported. As for the 4G modem type devices, I believe it depend on the USB class type required for your modem. As long as it is a supported class, it should be OK.
BR,
Edwin.
Thank you for contacting NXP support!
Are you using iMX8 or iMXRT?
Hi Chavira,
We are using MX RT1024.
Subash
