unable to load module vivante
1,294件の閲覧回数
prathameshghane
Hi all,
I am facing this error when try to run startx on imx6 board.
[    36.794] (II) LoadModule:"vivante"
[    36.808] (II) Loading /usr/lib/xorg/modules/input/vivante_drv.so
[   36.920] (EE) LoadModule: Module vivante does not have a vivanteModuleData data object.
[   36.920] (II) UnloadModule:"vivante"
[   36.920] (II) Unloading vivante
[   36.938] (EE) Failed to load module "vivante" (invalid module, 0)
[    36.938] (EE) No drivers available.
Can anyone help me in this regard??
Apart from this, can you also explain the standard procedure to bring up the vivante GPU during startup scripts?
Thanks and regards,
Prathamesh
ラベル(3)
0 返答(返信)
