i want to add usb support for uboot.
This is my uboot log:
U-Boot 2015.04-14472-gb5946f5-dirty (Aug 18 2016 - 09:49:11)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
CPU: Temperature 38 C
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 3.8 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 3
mmc get env dev=0
No panel detected: default to SAMSUNG-LTM230HL08
Display: SAMSUNG-LTM230HL08 (1920x1080)
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc0(part 0) is current device
Net: Phy 1 not found
PHY reset timed out
FEC [PRIME]
Normal Boot
Hit any key to stop autoboot: 0
i plug a usb disk to my custom board of imx6q, and run usb start command as follows:
=> usb start
starting USB...
USB0: Port not available.
=> usbboot
** No device specified **
=> usb reset
resetting USB...
Status indicator lamp of Usb disk is off, what should i do? usb disk can be read in linux kernel.
in uboot-imx/include/configs/mx6sabresd.h file:
80 /* USB Configs */
81 #define CONFIG_CMD_USB
82 #ifdef CONFIG_CMD_USB
83 #define CONFIG_USB_EHCI
84 #define CONFIG_USB_EHCI_MX6
85 #define CONFIG_USB_STORAGE
86 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET
87 #define CONFIG_USB_HOST_ETHER
88 #define CONFIG_USB_ETHER_ASIX
89 #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW)
90 #define CONFIG_MXC_USB_FLAGS 0
91 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Enabled USB controller number */
92 #endif
in uboot-imx/board/freescale/mx6sabresd/mx6sabresd.c file:
898 #ifdef CONFIG_USB_EHCI_MX6
899 #define USB_OTHERREGS_OFFSET 0x800
900 #define UCTRL_PWR_POL (1 << 9)
901
902 static iomux_v3_cfg_t const usb_otg_pads[] = {
903 MX6_PAD_EIM_D22__USB_OTG_PWR | MUX_PAD_CTRL(NO_PAD_CTRL),
904 MX6_PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(OTG_ID_PAD_CTRL),
905 };
906
907 static iomux_v3_cfg_t const usb_hc1_pads[] = {
908 MX6_PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL),
909 };
910
911 static void setup_usb(void)
912 {
913 imx_iomux_v3_setup_multiple_pads(usb_otg_pads,
914 ARRAY_SIZE(usb_otg_pads));
915
916 /*
917 * set daisy chain for otg_pin_id on 6q.
918 * for 6dl, this bit is reserved
919 */
920 imx_iomux_set_gpr_register(1, 13, 1, 0);
921
922 imx_iomux_v3_setup_multiple_pads(usb_hc1_pads,
923 ARRAY_SIZE(usb_hc1_pads));
924 }
