uStreamer porting for iMX8MM
3,059 次查看
r_trivedi123
I would like to use ustreamer with imx8 hardware encoder/decoder functionality.
it is possible to use for imx8 ? can you provide any suggetion on this?
https://github.com/pikvm/ustreamer, source that is used for raspberry pi board for streaming purpose.
Any help will be appreciable.
Thanks & Regards
4 回复数
2,994 次查看
r_trivedi123
Hi @Bio_TICFSL ,
Any pointer on the above would be helpful.
2,985 次查看
r_trivedi123
Hi @Bio_TICFSL ,
Can you help ?
3,035 次查看
Bio_TICFSL
Hello r_trivedi123
If this ustreamer is µStreamer (ustreamer) is a lightweight and very quick server to stream MJPG video from any V4L2 device to the network, yes it can support by every i.MX8.
3,029 次查看
r_trivedi123
Thank you for your reply.
Did test with µStreamer for iMX8MM board, and it works fine with  the camera input.
I have taken the dmesg logs for VPU logs entry  to check its usage and found that µStreamer is not using the VPU for encoding.
I found that  µStreamer uses the omx for encoding.
It is possible to get VPU(H/W) encoding with µStreamer? Any pointers in this ?
Any help will be appreciated.
