tuning failed for SDR50
1,114件の閲覧回数
litzchee
I am using an iMX8qxp on my custom board and I am experiencing tuning failed error when inserting a SDR50 SD card. This issue does not happen when I insert a SDR104 card.
Here is the device tree configuration
usdhc2: mmc@5b020000 {
		interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>;
		reg = <0x5b020000 0x10000>;
		clocks = <&sdhc1_lpcg 1>,
			 <&sdhc1_lpcg 0>,
			 <&sdhc1_lpcg 2>;
		clock-names = "ipg", "per", "ahb";
		assigned-clocks = <&clk IMX_SC_R_SDHC_1 IMX_SC_PM_CLK_PER>;
		assigned-clock-rates = <200000000>;
		power-domains = <&pd IMX_SC_R_SDHC_1>;
		fsl,tuning-start-tap = <20>;
		fsl,tuning-step= <2>;
		status = "disabled";
&usdhc2 {
	pinctrl-names = "default", "state_100mhz", "state_200mhz";
	pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
	pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
	pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
	bus-width = <4>;
	vmmc-supply = <&reg_usdhc2_vmmc>;
	cd-gpios = <&lsio_gpio4 22 GPIO_ACTIVE_LOW>;
	wp-gpios = <&lsio_gpio4 21 GPIO_ACTIVE_HIGH>;
	status = "okay";
I am wondering if trace length has something to do with this error. This is because previously I have tried on another board also using iMX8, but the SD card slot is nearer to the processor. In this case, I did not encounter any tuning failure for both SDR50 and SDR104
If trace length is the issue, what parameters I can tweak? Thanks
1,033件の閲覧回数
Rita_Wang
How about your usdhc2 hardware design? For the SD card design, for the IO power is 1.8V or 3.3V?
%3CLINGO-SUB%20id%3D%22lingo-sub-2135599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESDR50%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%20iMX8qxp%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SDR50%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%99%E3%82%8B%E3%81%A8%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E5%A4%B1%E6%95%97%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SDR104%20%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%99%E3%82%8B%E3%81%A8%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eusdhc2%3A%20mmc%405b020000%20%7B%0A%09%09interrupts%20%3D%20%3CGIC_SPI%20233%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%0A%09%09reg%20%3D%20%26lt%3B0x5b020000%200x10000%26gt%3B%3B%0A%09%09clocks%20%3D%20%26lt%3B%26amp%3Bsdhc1_lpcg%201%26gt%3B%2C%0A%09%09%09%20%26lt%3B%26amp%3Bsdhc1_lpcg%200%26gt%3B%2C%0A%09%09%09%20%26lt%3B%26amp%3Bsdhc1_lpcg%202%26gt%3B%3B%0A%09%09clock-names%20%3D%20%22ipg%22%2C%20%22per%22%2C%20%22ahb%22%3B%0A%09%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX_SC_R_SDHC_1%20IMX_SC_PM_CLK_PER%26gt%3B%3B%0A%09%09assigned-clock-rates%20%3D%20%26lt%3B200000000%26gt%3B%3B%0A%09%09power-domains%20%3D%20%26lt%3B%26amp%3Bpd%20IMX_SC_R_SDHC_1%26gt%3B%3B%0A%09%09fsl%2Ctuning-start-tap%20%3D%20%26lt%3B20%26gt%3B%3B%0A%09%09fsl%2Ctuning-step%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09status%20%3D%20%22disabled%22%3B%0A%09%7D%3B%0A%0A%26amp%3Busdhc2%20%7B%0A%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX_SC_R_SDHC_1%20IMX_SC_PM_CLK_PER%26gt%3B%3B%0A%09assigned-clock-rates%20%3D%20%26lt%3B200000000%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc2%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_usdhc2_gpio%26gt%3B%3B%0A%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc2_100mhz%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_usdhc2_gpio%26gt%3B%3B%0A%09pinctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc2_200mhz%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_usdhc2_gpio%26gt%3B%3B%0A%09bus-width%20%3D%20%26lt%3B4%26gt%3B%3B%0A%09vmmc-supply%20%3D%20%26lt%3B%26amp%3Breg_usdhc2_vmmc%26gt%3B%3B%0A%09cd-gpios%20%3D%20%26lt%3B%26amp%3Blsio_gpio4%2022%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%09wp-gpios%20%3D%20%26lt%3B%26amp%3Blsio_gpio4%2021%20GPIO_ACTIVE_HIGH%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%3C%2FGIC_SPI%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AE%E9%95%B7%E3%81%95%E3%81%8C%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E4%BB%A5%E5%89%8D%20iMX8%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%88%A5%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SD%20%E3%82%AB%E3%83%BC%E3%83%89%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%8C%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AB%E8%BF%91%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AECASE%E3%80%81SDR50%E3%81%A8SDR104%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E9%95%B7%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92CAN%E8%AA%BF%E6%95%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2135599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20tuning%20failed%20for%20SDR50%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eusdhc2%20%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3FSD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81IO%20%E9%9B%BB%E6%BA%90%E3%81%AF%201.8V%20%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%203.3V%20%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
