sudo command not found, on imx53board under linux
2,054 次查看
didier1
hi all,
it seems like the linux command "sudo" dosn't exist. I use ltib to generate my application.
Is it necessary to download "sudo" and compile it? or do i miss something?
thx
Seize
标签 (2)
1,970 次查看
LeonardoSandova
Specialist I
You are already root, there is no need to sudo any command. Or do you need it for something else?
Leo
1,970 次查看
didier1
Thx
Yes it s something else. For example I have to call "ntpd" from a script called from a html page in lighttpd (the user is www i think)
Clear?
