Hi again,
I noticed, that my Linux-Installation only recognizes two cpu-cores of the installed i.MX6Q, but I don't know why
Here is the configuration in my Device-Tree (copied from FSL SabreSD)
[CODE]
cpus {
#address-cells = <1>;
#size-cells = <0>;
cpu@0 {
compatible = "arm,cortex-a9";
device_type = "cpu";
reg = <0>;
next-level-cache = <&L2>;
operating-points = <
/* kHz uV */
1200000 1275000
996000 1250000
852000 1250000
792000 1150000
396000 975000
fsl,soc-operating-points = <
/* ARM kHz SOC-PU uV */
1200000 1275000
996000 1250000
852000 1250000
792000 1175000
396000 1175000
clock-latency = ; /* two CLK32 periods */
clocks = <&clks IMX6QDL_CLK_ARM>,
<&clks IMX6QDL_CLK_PLL2_PFD2_396M>,
<&clks IMX6QDL_CLK_STEP>,
<&clks IMX6QDL_CLK_PLL1_SW>,
<&clks IMX6QDL_CLK_PLL1_SYS>;
clock-names = "arm", "pll2_pfd2_396m", "step",
"pll1_sw", "pll1_sys";
arm-supply = <®_arm>;
pu-supply = <®_pu>;
soc-supply = <®_soc>;
cpu@1 {
reg = ;
cpu@2 {
reg = ;
cpu@3 {
reg = ;
}; [/CODE]
Why does Linux see only two cores?
