Dear all,
I am using customized imx6DL with sgtl5000-audio.
I have a issue about audio jack switch issue:
When insert headset, audio change from speaker to headset is ok.
After remove headset, the audio status still keep in headset inserted, and audio also didn't change back to speaker.
I had already confirm that headset detection gpio is correct.
When issue happened, the iMX6DL AUD_RXD is always low.
Is any one know what happened?
All suggestions are welcome.
Thanks.
