rpm_5.4.16.bb, do_compile build error
ahmetkoc
Hello everyone,
When i am trying to build compiler by using Yocto DISTRO ?= 'fsl-imx-fb' but there is error as i mentioned on the question keeps popping in while the progress is still going on. Compilation can not be finished. how can i fix this issue? Configuration files and error message can be reach by the link below. thank you in advance.
board  imx6qsabreauto
http://textuploader.com/d1j6c local config
http://textuploader.com/d1jja error message
Labels (3)
jimmychan
which board are you using? which BSP are you using? Could you tell me the steps of reproducing your issue? thanks.
