reg:uImage build error
vishvapathi
Contributor V
I am using LTIB and it had complied and build successfully. recently when i tried to rebuild its throwing following error. kindly point out did i make any mistake.
./ltib
Processing platform: Freescale iMX6x Based Boards
using config/platform/imx/.config
Processing: fake-provides
Processing: u-boot-v2009.08
Processing: kernel-3.0.35
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/tmp' --define '_rpmdir /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bb  /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/tmp/kernel-3.0.35.spec
Building target platforms: arm
Building for target arm
Executing(%prep): /bin/sh -e /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/tmp/rpm-tmp.72942
+ umask 022
+ cd /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD
+ echo imx_4.0.0
+ cut -d_ -f2
+ rel_ver=4.0.0
+ echo imx_4.0.0
+ cut -d. -f3
+ cut -c2
+ zz=
+ git_tag=rel_imx_3.0.35_4.0.0
+ [  != 0 ]
+ git_br=imx_3.0.35_4.0.0
+ KSRC_DIR=/home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux-3.0.35
+ [ -z y ]
+ [ ! -d /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux-3.0.35 ]
+ exit 0
Executing(%build): /bin/sh -e /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/tmp/rpm-tmp.72942
+ umask 022
+ cd linux-3.0.35
+ eval echo
+ echo
+ PKG_KERNEL_PATH_PRECONFIG=
+ eval echo
+ echo
+ PKG_KERNEL_KBUILD_PRECONFIG=
+ eval echo imx6_defconfig
+ echo imx6_defconfig
+ PKG_KERNEL_PRECONFIG=imx6_defconfig
+ : arm
+ : ccache /usr/bin/gcc -B/usr/bin/
+ : imx6_defconfig
+ : /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx
+ : /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux-3.0.35
+ rm -f /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux
+ ln -s /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux-3.0.35 /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux
+ cd /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/linux-3.0.35
+ KBOUT=
+ [ -n  -a  != . ]
+ KBOUT=.
+ KTARG=zImage
+ SYSCFG_KTARG=uImage
+ [ imx6_defconfig = defconfig ]
+ [ -f /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx/imx6_defconfig.dev ]
+ CFG_PATH=/home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx/imx6_defconfig.dev
+ break
+ [ -z /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx/imx6_defconfig.dev ]
+ [ arm = ppc -a -f arch/powerpc/Kconfig ]
+ [ -n  ]
+ [ -n /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx/imx6_defconfig.dev ]
+ cp -f /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx/imx6_defconfig.dev ./.config
+ [ -z  -a -n y -o -n  ]
+ make ARCH=arm CROSS_COMPILE= HOSTCC=ccache /usr/bin/gcc -B/usr/bin/ menuconfig
scripts/kconfig/mconf Kconfig
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
+ diff -q ./.config /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/config/platform/imx/imx6_defconfig.dev
+ [ -n  ]
+ grep -q VERSION = 2 Makefile
+ [ %{kernel_series} = 2.4 ]
+ make ARCH=arm CROSS_COMPILE= HOSTCC=ccache /usr/bin/gcc -B/usr/bin/ uImage
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  MK_FW   firmware/<.gen.S
/bin/sh: cannot create firmware/: Is a directory
make[1]: *** [firmware/<.gen.S] Error 2
make: *** [firmware] Error 2
make: *** Waiting for unfinished jobs....
  GZIP    kernel/config_data.gz
  IKCFG   kernel/config_data.h
  CC      kernel/configs.o
  LD      kernel/built-in.o
error: Bad exit status from /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/tmp/rpm-tmp.72942 (%build)
RPM build errors:
Build time for kernel-3.0.35: 8 seconds
Failed building kernel-3.0.35
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Sat Dec 14 18:32:22 2013
Ended:   Sat Dec 14 18:32:30 2013
Elapsed: 8 seconds
These packages failed to build:
kernel-3.0.35
Build Failed
Labels (2)
Yuri
It makes sense to try the recent BSP - L3.0.35_4.1.0
vishvapathi
Contributor V
Hi Yuri,
  I have the recent BSP also. When i rebuilt i got few errors in that also. Will post the errors.
vishvapathi
Contributor V
Still i am getting the same error. when i built kernel separately kernel is build successfully. But i need to add some modules so i am rebuilding kernel in ltib. how to overome this issue?
vishvapathi
Contributor V
Kindly advice how to manually create modules?? for webcam,v4l.
LeonardoSandova
Specialist I
Can you try cleaning the kernel? I am not on my linux host but I think it is
ltib -m clean -p kernel
then try ltib cmd again.
If this does not work, remove completely the rpm/BUILD/linux-3.* folder.
Leo
vishvapathi
Contributor V
Hi Leo,
I tried both, still i am getting the same error.
