problem facing for installation ltib
HimanshuDobhal
Hi everyone,
I am trying to install ltib on my Ubuntu 10.4 LTS. but it failed every time and showing me the error that it cant fetch mtd-ulits. So can anyone please guide me for the installation........
thank in advance
KrishnaPavan
Yeah! If you are using a BSP like 11.09... ... etc, then probably you should have a look at this link.
http://imxcommunity.org/profiles/blogs/new-linux-11-09-bsp-patch-for-the-i-mx53?xg_source=activity
One thing you can do is to attach the log file < host_config.log > so that it shall be useful in understanding what actually is the cause for the problem!
~~Regards :: Krishna Pavan~~
SumitVaidya
I am also facing the same problem while compiling latest BSP  L3.0.35_1.1.0_121218_source.tar.gz. The build fails at mtd-utils package.
Below is the log:
Processing platform: Host support packages
using /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: autoconf
Processing: libtool
Processing: lkc
Processing: wget
Processing: uclinux-cksum
Processing: genext2fs
Processing: genromfs
Processing: gen_init_cpio
Processing: u-boot-tools
Processing: mtd-utils
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/dist/lfs-5.1/mtd-utils/mtd-utils.spec
Building target platforms: i686
Building for target i686
Executing(%prep): /bin/sh -e /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/tmp/rpm-tmp.83205
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ rm -rf mtd-utils
+ /bin/gzip -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/mtd-utils-1.5.0.tar.gz
+ tar -xvvf -
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/
-rw-rw-r-- root/root       764 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/.gitignore
-rw-rw-r-- root/root     18007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/COPYING
-rwxrwxr-x root/root       786 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/MAKEDEV
-rw-rw-r-- root/root      3134 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/Makefile
-rw-rw-r-- root/root      2007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/common.mk
-rw-rw-r-- root/root     14720 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr.c
-rw-rw-r-- root/root      3343 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr.h
-rw-rw-r-- root/root      3039 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr_lzo.c
-rw-rw-r-- root/root      2659 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr_rtime.c
-rw-rw-r-- root/root      3941 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr_zlib.c
-rw-rw-r-- root/root      4244 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/device_table.txt
-rw-rw-r-- root/root      3301 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/doc_loadbios.c
-rw-rw-r-- root/root      8901 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/docfdisk.c
-rw-rw-r-- root/root       308 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/feature-removal-schedule.txt
-rw-rw-r-- root/root      1980 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/fectest.c
-rw-rw-r-- root/root      7570 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_erase.c
-rwxrwxr-x root/root       150 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_eraseall
-rw-rw-r-- root/root       154 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_lock.c
-rw-rw-r-- root/root      1085 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_dump.c
-rw-rw-r-- root/root      1308 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_info.c
-rw-rw-r-- root/root      1588 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_lock.c
-rw-rw-r-- root/root      2019 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_write.c
-rw-rw-r-- root/root      2158 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_unlock.c
-rw-rw-r-- root/root     10817 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flashcp.c
-rw-rw-r-- root/root      6427 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ftl_check.c
-rw-rw-r-- root/root      9485 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ftl_format.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/
-rw-rw-r-- root/root      4597 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/common.h
-rw-rw-r-- root/root       294 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/crc32.h
-rw-rw-r-- root/root     11661 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/libmtd.h
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/linux/
-rw-rw-r-- root/root      7033 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/linux/jffs2.h
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/
-rw-rw-r-- root/root      2646 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/ftl-user.h
-rw-rw-r-- root/root      1674 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/inftl-user.h
-rw-rw-r-- root/root      2371 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/jffs2-user.h
-rw-rw-r-- root/root      9304 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/mtd-abi.h
-rw-rw-r-- root/root      1199 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/mtd-user.h
-rw-rw-r-- root/root      1401 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/nftl-user.h
-rw-rw-r-- root/root     16929 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/ubi-media.h
-rw-rw-r-- root/root     15492 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/ubi-user.h
-rw-rw-r-- root/root      1903 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd_swab.h
-rw-rw-r-- root/root      2469 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/xalloc.h
-rw-rw-r-- root/root      8622 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/jffs-dump.c
-rw-rw-r-- root/root     22295 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/jffs2dump.c
-rw-rw-r-- root/root     21350 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/jffs2reader.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/
-rw-rw-r-- root/root      5567 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libcrc32.c
-rw-rw-r-- root/root     24552 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libfec.c
-rw-rw-r-- root/root     33433 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libmtd.c
-rw-rw-r-- root/root      3629 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libmtd_int.h
-rw-rw-r-- root/root      9135 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libmtd_legacy.c
-rwxrwxr-x root/root      4309 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/load_nandsim.sh
-rwxrwxr-x root/root      2035 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/make_a_release.sh
-rw-rw-r-- root/root      1537 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mcast_image.h
-rw-rw-r-- root/root      6782 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.jffs2.1
-rw-rw-r-- root/root     48903 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.jffs2.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/
-rw-rw-r-- root/root        12 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/.gitignore
-rw-rw-r-- root/root     18007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/COPYING
-rw-rw-r-- root/root       608 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/README
-rw-rw-r-- root/root      4680 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/compr.c
-rw-rw-r-- root/root      1437 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/compr.h
-rw-rw-r-- root/root      2618 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/crc16.c
-rw-rw-r-- root/root       599 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/crc16.h
-rw-rw-r-- root/root      1990 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/defs.h
-rw-rw-r-- root/root     14732 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/devtable.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/
-rw-rw-r-- root/root      9064 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable.c
-rw-rw-r-- root/root      7374 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable.h
-rw-rw-r-- root/root      5783 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable_itr.c
-rw-rw-r-- root/root      4086 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable_itr.h
-rw-rw-r-- root/root      2955 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable_private.h
-rw-rw-r-- root/root      5078 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/key.h
-rw-rw-r-- root/root     15842 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/lpt.c
-rw-rw-r-- root/root       980 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/lpt.h
-rw-rw-r-- root/root     62542 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/mkfs.ubifs.c
-rw-rw-r-- root/root      4435 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/mkfs.ubifs.h
-rw-rw-r-- root/root     22044 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/ubifs-media.h
-rw-rw-r-- root/root     11642 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/ubifs.h
-rw-rw-r-- root/root       727 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mtd-utils.spec
-rw-rw-r-- root/root      9296 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mtd_debug.c
-rw-rw-r-- root/root     13597 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nanddump.c
-rw-rw-r-- root/root      6206 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nandtest.c
-rw-rw-r-- root/root     14637 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nandwrite.c
-rw-rw-r-- root/root     12460 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nftl_format.c
-rw-rw-r-- root/root      7826 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nftldump.c
-rw-rw-r-- root/root      8620 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rbtree.c
-rw-rw-r-- root/root      5247 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rbtree.h
-rw-rw-r-- root/root     14837 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/recv_image.c
-rw-rw-r-- root/root      7315 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rfddump.c
-rw-rw-r-- root/root      3412 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rfdformat.c
-rw-rw-r-- root/root      7837 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/serve_image.c
-rw-rw-r-- root/root      4860 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/summary.h
-rw-rw-r-- root/root     25396 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/sumtool.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/
-rw-rw-r-- root/root       141 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/Makefile
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/
-rw-rw-r-- root/root        20 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/.gitignore
-rw-rw-r-- root/root       101 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/Makefile
-rw-rw-r-- root/root      6989 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/README
-rw-rw-r-- root/root     21657 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/checkfs.c
-rw-rw-r-- root/root      1197 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/comm.c
-rw-rw-r-- root/root       216 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/common.h
-rw-rw-r-- root/root      8520 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/makefiles.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/
-rw-rw-r-- root/root       137 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/Makefile
-rwxrwxr-x root/root      1420 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/help_all.sh
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/
-rw-rw-r-- root/root         9 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/.gitignore
-rw-rw-r-- root/root       674 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/Makefile
-rw-rw-r-- root/root     78377 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/integck.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/
-rw-rw-r-- root/root       166 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/Makefile
-rw-rw-r-- root/root     30375 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/tests.c
-rw-rw-r-- root/root      7328 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/tests.h
-rwxrwxr-x root/root       715 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/run_all.sh
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/
-rw-rw-r-- root/root        36 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/.gitignore
-rw-rw-r-- root/root       350 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/Makefile
-rw-rw-r-- root/root      2668 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/ftrunc.c
-rw-rw-r-- root/root      4633 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/orph.c
-rw-rw-r-- root/root      5097 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/perf.c
-rw-rw-r-- root/root      4370 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/test_1.c
-rw-rw-r-- root/root      6356 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/test_2.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/
-rw-rw-r-- root/root       150 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/Makefile
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/
-rw-rw-r-- root/root        99 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/.gitignore
-rw-rw-r-- root/root       511 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/Makefile
-rw-rw-r-- root/root      5820 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/fwrite00.c
-rw-rw-r-- root/root      5322 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/gcd_hupper.c
-rw-rw-r-- root/root      3646 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/pdfrun.c
-rw-rw-r-- root/root      3692 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rmdir00.c
-rw-rw-r-- root/root      4329 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rndrm00.c
-rw-rw-r-- root/root     10320 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rndrm99.c
-rw-rw-r-- root/root      5282 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rndwrite00.c
-rw-rw-r-- root/root      2655 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/stress_1.c
-rw-rw-r-- root/root      3011 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/stress_2.c
-rw-rw-r-- root/root      3129 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/stress_3.c
-rwxrwxr-x root/root      1124 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/stress00.sh
-rwxrwxr-x root/root       644 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/stress01.sh
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/
-rw-rw-r-- root/root        28 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/.gitignore
-rw-rw-r-- root/root       250 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/Makefile
-rw-rw-r-- root/root      1510 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/free_space.c
-rw-rw-r-- root/root      5272 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/fstest_monitor.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/
-rw-rw-r-- root/root        30 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/.gitignore
-rw-rw-r-- root/root     18007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/COPYING
-rw-rw-r-- root/root     34759 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/JitterTest.c
-rw-rw-r-- root/root      1782 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/Makefile
-rw-rw-r-- root/root      6727 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/README
-rw-rw-r-- root/root       250 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/filljffs2.sh
-rw-rw-r-- root/root     10267 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/plotJittervsFill.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/
-rw-rw-r-- root/root       102 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/.gitignore
-rw-rw-r-- root/root       702 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/Makefile
-rw-rw-r-- root/root      1253 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/README.udev
-rw-rw-r-- root/root      8942 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/common.c
-rw-rw-r-- root/root      4775 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/common.h
-rw-rw-r-- root/root     19103 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/integ.c
-rw-rw-r-- root/root      4265 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_basic.c
-rw-rw-r-- root/root      7460 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_paral.c
-rw-rw-r-- root/root      8614 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_read.c
-rw-rw-r-- root/root      7133 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_update.c
-rw-rw-r-- root/root      7348 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/mkvol_bad.c
-rw-rw-r-- root/root      5441 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/mkvol_basic.c
-rw-rw-r-- root/root      2484 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/mkvol_paral.c
-rw-rw-r-- root/root      6542 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/rsvol.c
-rwxrwxr-x root/root       616 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/runtests.sh
-rw-rw-r-- root/root      3026 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/volrefcnt.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/
-rw-rw-r-- root/root       124 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/.gitignore
-rw-rw-r-- root/root      1083 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/LICENSE.libiniparser
-rw-rw-r-- root/root     11442 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/dictionary.c
drwxrwxr-x root/root         0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/
-rw-rw-r-- root/root      6589 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/dictionary.h
-rw-rw-r-- root/root     10270 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libiniparser.h
-rw-rw-r-- root/root      3156 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libscan.h
-rw-rw-r-- root/root     16285 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libubi.h
-rw-rw-r-- root/root      6131 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libubigen.h
-rw-rw-r-- root/root      1120 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/ubiutils-common.h
-rw-rw-r-- root/root     20001 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libiniparser.c
-rw-rw-r-- root/root      5548 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libscan.c
-rw-rw-r-- root/root     30363 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libubi.c
-rw-rw-r-- root/root      4293 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libubi_int.h
-rw-rw-r-- root/root      8463 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libubigen.c
-rw-rw-r-- root/root     11179 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/mtdinfo.c
-rw-rw-r-- root/root      6215 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiattach.c
-rw-rw-r-- root/root      2797 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubicrc32.c
-rw-rw-r-- root/root      5447 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubidetach.c
-rw-rw-r-- root/root     24677 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiformat.c
-rw-rw-r-- root/root      8288 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubimkvol.c
-rw-rw-r-- root/root     11685 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubinfo.c
-rw-rw-r-- root/root     19997 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubinize.c
-rw-rw-r-- root/root      4002 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubirename.c
-rw-rw-r-- root/root      5076 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubirmvol.c
-rw-rw-r-- root/root      6284 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubirsvol.c
-rw-rw-r-- root/root      7280 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiupdatevol.c
-rw-rw-r-- root/root      5019 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiutils-common.c
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd mtd-utils
cd: 1: can't cd to mtd-utils
error: Bad exit status from /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/tmp/rpm-tmp.83205 (%prep)
RPM build errors:
Build time for mtd-utils: 0 seconds
Failed building mtd-utils
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Tue Feb 26 16:31:07 2013
Ended:   Tue Feb 26 16:31:07 2013
Elapsed: 0 seconds
These packages failed to build:
mtd-utils
Build Failed
Please let me know the cause of this error and how should I fix this?
Sumit
SumitVaidya
This is resolved now. I had to delete /tmp/rpm-lucid directory to remove old traces of installed LTIB. I unset some environment variables that were linked to my development machine and had a reference to old LTIB. Then I restarted my machine and did fresh installation. It worked fine.
Thanks.
Sumit
mdc
Contributor V
HimanshuDobhal
Hi Krishna,
    Yes sir I already install both the thing...................
KrishnaPavan
Hi Himanshu,
Do you have mtd-utils and mtd-tools both installed on your host?
HimanshuDobhal
Thanks Krishna
    I have already install mtd-ulits but then also it is showing that the utility is not available. So can you tell me any other way to install ltib.
thanks for your response
KrishnaPavan
Hi Himanshu,
means that the developer files are not available on your Host.
Install them using Software Sources / Synaptics...
