plugin Gstreamer pour IMX 95
4,322 次查看
OlivierG
I'm trying to get gstreamer on Yocto on an IMX 95 verdin card with a minimal image.
I have the gstreamer executable but without any plugins.
What line should I put in local.conf for the Bitbake recipe?
I need the plugin for H264 compression, in particular.
Greetings
Olivier
9 回复数
4,139 次查看
OlivierG
The problem is not the command line
The Yocto build doest not provide any gstreamer plugin.
Whatever the command, I get
ERROR: pipeline could not be constructed: no element <plugin name>
What line should i put in local.conf for the Bitbake recipe?
Greetings
Olivier
4,093 次查看
Bio_TICFSL
Yes, you build the bitbake imx-image-full, now the iMX95 still on beta phase where it can not be possible to obtain the fill gstreamer functionality.
4,075 次查看
OlivierG
I build the imx-image-full and i get the followings errors
ERROR: onnxruntime-1.17.1-r0 do_configure: ExecutionError('/home/olivier/Dev/yocto/buildImx95Full/tmp/work/armv8a-poky-linux/onnxruntime/1.17.1/temp/run.do_configure.553602', 1, None, None)
ERROR: Logfile of failure stored in: /home/olivier/Dev/yocto/buildImx95Full/tmp/work/armv8a-poky-linux/onnxruntime/1.17.1/temp/log.do_configure.553602
ERROR: Task (/home/olivier/Dev/yocto/sources/meta-imx/meta-imx-ml/recipes-libraries/onnxruntime/onnxruntime_1.17.1.bb:do_configure) failed with exit code '1'
Greetings
Olivier
4,067 次查看
Bio_TICFSL
Please download the 6.6.52 BSP that has better performance with the MX95:
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
and erase and restart for scratch yocto.
4,038 次查看
OlivierG
i upgrade to the latest version
I get:
ERROR: tensorflow-lite-2.18.0-r0 do_configure: Execution of '/home/olivier/Dev/Yocto2/buildImx95/tmp/work/armv8a-mx95-poky-linux/tensorflow-lite/2.18.0/temp/run.do_configure.1782864' failed with exit code 1
ERROR: Logfile of failure stored in: /home/olivier/Dev/Yocto2/buildImx95/tmp/work/armv8a-mx95-poky-linux/tensorflow-lite/2.18.0/temp/log.do_configure.1782864
ERROR: Task (/home/olivier/Dev/Yocto2/sources/meta-imx/meta-imx-ml/recipes-libraries/tensorflow-lite/tensorflow-lite_2.18.0.bb:do_configure) failed with exit code '1'
I precise that i need tensorflow
Greetings
Olivier
3,936 次查看
OlivierG
Finally the problem is due to a download problem du to the firewall
Olivier
4,031 次查看
Bio_TICFSL
The error is different to the first thread please Create a new one for this, but erase everything and reintalls
3,975 次查看
OlivierG
I started from a blank directory
the error is due to a download problem
https://gitlab.arm.com/kleidi/kleidiai/-/archive/cddf991af5de49fd34949fa39690e4e906e04074/kleidiai-c...
is not available
https://github.com/ARM-software/kleidiai/archive/cddf991af5de49fd34949fa39690e4e906e04074.zip is available
i would like to modify the recipe to download this link instead
Attached the entire error log
Greetings
Olivier
4,313 次查看
Bio_TICFSL
The i.MX95 utilizes GStreamer as its multimedia framework. Specifically, the gstreamer-imx plugins, which leverage the i.MX multimedia capabilities, are used on this platform. Yocto Linux, a common embedded Linux distribution, also uses GStreamer as its default multimedia framework, you need to build the imx-image-multimedia or the imx-image-full to have it.
The i.MX95 SoC features 4K@60fps H.264/H.265 VPU decoder.
Before starting video playback, please, ensure that the display is connected to the board.
The following commands can be used to start video playback (1.mov is a media file):
  • gst-play
gst-play /path/to/1.mov
  • gplay-1.0
gplay-1.0 /path/to/1.mov
  • gst-launch
This method is for advanced users. Please study this document before the start: i.MX8GStreamerUserGuide.pdf
gst-launch-1.0 -v filesrc location=/path/to/1.mov ! qtdemux name=d.video_0 ! h264parse ! avdec_h264 ! autovideosink
%3CLINGO-SUB%20id%3D%22lingo-sub-2136558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGstreamer%20pour%20IMX%2095%20%E6%8F%92%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHI%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E5%9C%A8%20IMX%2095%20verdin%20%E5%8D%A1%E4%B8%8A%E7%9A%84%20Yocto%20%E4%B8%8A%E5%AE%89%E8%A3%85%20gstreamer%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%9C%80%E5%B0%8F%E9%95%9C%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%9C%89%20gstreamer%20%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E6%8F%92%E4%BB%B6%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%20local.conf%20%E4%B8%AD%E4%B8%BA%20Bitbake%20%E9%85%8D%E6%96%B9%20%E5%8A%A0%E5%93%AA%E4%B8%80%E8%A1%8C%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%B0%A4%E5%85%B6%E9%9C%80%E8%A6%81%20H264%20%E5%8E%8B%E7%BC%A9%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%82%A8%E5%A5%BD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E9%98%B2%E7%81%AB%E5%A2%99%E7%9A%84%E4%B8%8B%E8%BD%BD%E9%97%AE%E9%A2%98%E4%B8%8A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%E7%A9%BA%E7%99%BD%E7%9B%AE%E5%BD%95%E5%BC%80%E5%A7%8B%3C%2FP%3E%3CP%3E%E8%AF%A5%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E4%BA%8E%E4%B8%8B%E8%BD%BD%E9%97%AE%E9%A2%98%E9%80%A0%E6%88%90%E7%9A%84%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgitlab.arm.com%2Fkleidi%2Fkleidiai%2F-%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074%2Fkleidiai-cddf991af5de49fd34949fa39690e4e906e04074.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.arm.com%2Fkleidi%2Fkleidiai%2F-%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074%2Fkleidiai-cddf991af5de49fd34949fa39690e4e906e04074.zip%3C%2FA%3E%3CBR%20%2F%3E%E4%B8%8D%E5%8F%AF%E7%94%A8%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FARM-software%2Fkleidiai%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FARM-software%2Fkleidiai%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074.zip%3C%2FA%3E%E5%8F%AF%E7%94%A8%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BF%AE%E6%94%B9%E9%85%8D%E6%96%B9%E6%94%B9%E4%B8%BA%E4%B8%8B%E8%BD%BD%E8%BF%99%E4%B8%AA%E9%93%BE%E6%8E%A5%3C%2FP%3E%3CP%3E%E9%99%84%E4%B8%8A%E6%95%B4%E4%B8%AA%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E5%A5%BD%3C%2FP%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%E4%B8%8E%E7%AC%AC%E4%B8%80%E4%B8%AA%E4%B8%BB%E9%A2%98%E4%B8%8D%E5%90%8C%EF%BC%8C%E8%AF%B7%E4%B8%BA%E6%AD%A4%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%BD%86%E8%AF%B7%E6%B8%85%E9%99%A4%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E5%B9%B6%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%88%91%E5%8D%87%E7%BA%A7%E5%88%B0%E4%BA%86%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Atensorflow-lite-2.18.0-r0%20do_configure%EF%BC%9A%E6%89%A7%E8%A1%8C%20%E2%80%9C%2FHOME%2FOlivier%2Fdev%2Fyocto2%2Fbuildimx95%2Ftmp%2Fwork%2Farmv8a-mx95-%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82-linux%2FTensorflow-Lite%2F2.18.0%2Ftemp%2Frun.do_configure.1782864%E2%80%9D%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%201%20%3CBR%20%2F%3E%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2FHOME%2FOLIVIER%2Fdev%2Fyocto2%2Fbuildimx95%2Ftmp%2Fwork%2Farmv8a-mx95-%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82-linux%2FTensorflow-Lite%2F2.18.0%2Ftemp%2Flog.do_configure.1782864%20%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%2FHOME%2FOlivier%2Fdev%2Fyocto2%2Fsources%2Fmeta-imx%2Fmeta-imx-ML%2F%E9%85%8D%E6%96%B9%E5%BA%93%2FTensorflow-Lite%2FTensorflow-Lite_2.18.0.bb%3A%20do_configure%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%20%E2%80%9C1%E2%80%9D%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%BC%A0%E9%87%8F%E6%B5%81%3C%2FP%3E%3CP%3E%E6%82%A8%E5%A5%BD%3C%2FP%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E4%B8%8B%E8%BD%BD%20MX95%20%E6%80%A7%E8%83%BD%E6%9B%B4%E5%A5%BD%E7%9A%84%206.6.52%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%93%A6%E9%99%A4%E5%B9%B6%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E5%88%92%E7%97%95%E8%BD%AF%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%88%91%E7%89%88%E6%9C%AC%E4%BA%86%20imx-image-full%20%E4%BD%86%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Aonnxruntime-1.17.1-r0%20do_configure%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%94%99%E8%AF%AF%EF%BC%88'%2FHOME%2FOlivier%2Fdev%2Fyocto%2Fbuildimx95full%2Ftmp%2Fwork%2Farmv8a-%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82-linux%2Fonnxruntime%2Fonnxruntime%2F1.17.1%2Ftemp%2Frun.do_configure.553602'%EF%BC%8C1%EF%BC%8C%E6%97%A0%EF%BC%8C%E6%97%A0%EF%BC%89%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2FHOME%2FOLIVIER%2FDEVIER%2FDEVIRE%2FDEVIRE%2FDEVILER%2FDEVILER%2FDEVILER%2FDEVILE%2Fyocto%2Fbuildimx95full%2Ftmp%2Fwork%2Farmv8a-%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82-linux%2Fonnxruntime%2F1.17.1%2Ftemp%2Flog.do_configure.553602%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%2FHOME%2FOlivier%2Fdev%2Fyocto%2Fsources%2Fmeta-imx%2Fmeta-imx-ML%2F%E9%85%8D%E6%96%B9%E5%BA%93%2Fonnxruntime%2Fonnxruntime%2Fonnxruntime_1.17.1.bb%3A%20do_configure%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%20%221%3C%2FP%3E%3CP%3E%E6%82%A8%E5%A5%BD%3C%2FP%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E7%89%88%E6%9C%AC%E4%BA%86%20bitbake%20imx-image-full%EF%BC%8C%E7%8E%B0%E5%9C%A8%20iMx95%20%E4%BB%8D%E5%A4%84%E4%BA%8E%E6%B5%8B%E8%AF%95%E9%98%B6%E6%AE%B5%EF%BC%8C%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E5%A1%AB%E5%85%85%20gstreamer%20%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E4%B8%8D%E5%9C%A8%E4%BA%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%3C%2FP%3E%3CP%3EYocto%20%E7%89%88%E6%9C%AC%E4%B8%8D%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%20gstreamer%20%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A0%E8%AE%BA%E4%BD%BF%E7%94%A8%E4%BB%80%E4%B9%88%E5%91%BD%E4%BB%A4%EF%BC%8C%E6%88%91%E9%83%BD%E4%BC%9A%E5%BE%97%E5%88%B0%3CBR%20%2F%3EERROR%3A%20pipeline%20could%20not%20be%20constructed%3A%20no%20element%3CPLUGIN%20name%3D%22%22%3E%3C%2FPLUGIN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%20local.conf%20%E4%B8%AD%E4%B8%BA%20Bitbake%20%E9%85%8D%E6%96%B9%E5%8A%A0%E5%93%AA%E4%B8%80%E8%A1%8C%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E5%A5%BD%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A5%A5%E5%88%A9%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%2217349224196443715229%22%3Ei.MX95%20%E4%BD%BF%E7%94%A8%20GStreamer%20%E4%BD%9C%E4%B8%BA%E5%85%B6%E5%A4%9A%E5%AA%92%E4%BD%93%E6%A1%86%E6%9E%B6%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%2217349224196443716500%22%3E%E5%85%B7%E4%BD%93%E8%80%8C%E8%A8%80%EF%BC%8C%E8%AF%A5%E5%B9%B3%E5%8F%B0%E4%B8%8A%E4%BD%BF%E7%94%A8%E4%BA%86%E5%88%A9%E7%94%A8i.MX%E5%A4%9A%E5%AA%92%E4%BD%93%E5%8A%9F%E8%83%BD%E7%9A%84gstreamer-imx%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%2217349224196443713675%22%3EYocto%20Linux%20%E6%98%AF%E4%B8%80%E7%A7%8D%E5%B8%B8%E8%A7%81%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%20Linux%20%E5%8F%91%E8%A1%8C%E7%89%88%EF%BC%8C%E5%AE%83%E4%B9%9F%E4%BD%BF%E7%94%A8%20GStreamer%20%E4%BD%9C%E4%B8%BA%E5%85%B6%E9%BB%98%E8%AE%A4%E7%9A%84%E5%A4%9A%E5%AA%92%E4%BD%93%E6%A1%86%E6%9E%B6%EF%BC%8C%E4%BD%A0%E9%9C%80%E8%A6%81%E7%89%88%E6%9C%AC%20imx-image-multimedia%20%E6%88%96%20imx-image-full%20%E6%89%8D%E8%83%BD%E6%8B%A5%E6%9C%89%E5%AE%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ei.MX95%20SoC%20%E5%85%B7%E6%9C%89%204K%4060fps%20H.264%2FH.265%20VPU%20%E8%A7%A3%E7%A0%81%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E5%BC%80%E5%A7%8B%E8%A7%86%E9%A2%91%E6%92%AD%E6%94%BE%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%98%BE%E7%A4%BA%E5%99%A8%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9D%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%90%AF%E5%8A%A8%E8%A7%86%E9%A2%91%E6%92%AD%E6%94%BE%3CSTRONG%3E%EF%BC%881.mov%3C%2FSTRONG%3E%E4%B8%BA%E5%AA%92%E4%BD%93%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Egst-play%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20translate%3D%22no%22%3Egst-play%20%2Fpath%2Fto%2F1.mov%0A%3C%2FPRE%3E%0A%3CUL%3E%0A%3CLI%3Egplay-1.0%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20translate%3D%22no%22%3Egplay-1.0%20%2Fpath%2Fto%2F1.mov%0A%3C%2FPRE%3E%0A%3CUL%3E%0A%3CLI%3Egst%20%E5%8F%91%E5%B8%83%E4%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%AD%A4%E6%96%B9%E6%B3%95%E9%80%82%E7%94%A8%E4%BA%8E%E9%AB%98%E7%BA%A7%E7%94%A8%E6%88%B7%E3%80%82%E8%AF%B7%E5%9C%A8%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E5%89%8D%E9%98%85%E8%AF%BB%E6%9C%AC%E6%96%87%E6%A1%A3%EF%BC%9A%3CA%20class%3D%22external%20text%22%20href%3D%22https%3A%2F%2Fraw.githubusercontent.com%2Fcompulab-yokneam%2FDocumentation%2Fmaster%2Fpdfs%2Fi.MX8GStreamerUserGuide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX8GStreamerUserGuide.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Egst-launch-1.0%20-v%20filesrc%20location%3D%2Fpath%2Fto%2F1.mov%26nbsp%3B!%20qtdemux%20name%3Dd.video_0%26nbsp%3B!%20h264parse%26nbsp%3B!%20avdec_h264%26nbsp%3B!%20autovideosink%3C%2FPRE%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
