ping command packet loss
4,334 次查看
sandeep_c
hi everyone iam developing the driver for ksz 8851snli by using lwip stack which spi to ethernet and vice versa
IDE DETAILS:
i.MX RT1170 First GHz Crossover MCU with Arm® Cortex®-M7 and Cortex-M4 Cores
MCUXpresso IDE v11.6.0 [Build 8187] [2022-07-13]
problem:
iam trying ping between pc to mc and vice versa during this time i will get all for responses and sometimes i will loss 3 or 2 or 1 packets or all packets please refer the document .
i havent found at what frequency clock will generated by the laptop (pc) for request or reply
what are the procedure or how can i solve this issue i need some insight from the community.
my processor clock configured as 500khz
Microsoft Windows [Version 10.0.19045.2728]
(c) Microsoft Corporation. All rights reserved.
C:\Users\admin>ping 192.168.0.102
Pinging 192.168.0.102 with 32 bytes of data:
Reply from 192.168.0.100: Destination host unreachable.
Ping statistics for 192.168.0.102:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1746ms TTL=255
Request timed out.
Approximate round trip times in milli-seconds:
Minimum = 1746ms, Maximum = 1746ms, Average = 1746ms
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2574ms TTL=255
Minimum = 2574ms, Maximum = 2574ms, Average = 2574ms
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2773ms TTL=255
Request timed out.
Request timed out.
Minimum = 2773ms, Maximum = 2773ms, Average = 2773ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
General failure.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2039ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2056ms TTL=255
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 2039ms, Maximum = 2056ms, Average = 2047ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=919ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1229ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1783ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=3489ms TTL=255
Minimum = 919ms, Maximum = 3489ms, Average = 1855ms
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=869ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1410ms TTL=255
Minimum = 869ms, Maximum = 1410ms, Average = 1139ms
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2085ms TTL=255
Minimum = 2085ms, Maximum = 2085ms, Average = 2085ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1253ms TTL=255
Request timed out.
Request timed out.
Request timed out.
Minimum = 1253ms, Maximum = 1253ms, Average = 1253ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=811ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1160ms TTL=255
Request timed out.
Request timed out.
Minimum = 811ms, Maximum = 1160ms, Average = 985ms
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=3658ms TTL=255
Request timed out.
Request timed out.
Minimum = 3658ms, Maximum = 3658ms, Average = 3658ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
@Ethernet @tcp_ipstack @EthernetHelp @ethernet1
thank you
4,273 次查看
jingpan
Hi @sandeep_c ,
It seems there is either software problem or hardware problem. The link is not established at all.
Jing
