patch for NAND Flash
4,170 次查看
Harris
Is there a patch to resolve NAND Flash driver.
I found the Spansion NAND S34ML08G1 can not be support by IMX6Q.
Thanks.
3,839 次查看
Hi Harris
general steps for adding new nand support are as follows
(there may be slight differencies depending on kernel):
add support as describes attached Add new_NAND support.pdf.
Then rebuild MFG Tool firmware (initramfs.cpio.gz.uboot), as
describes sect.3.9 "Build Manufacturing Firmware"
i.MX_6DualQuad_SABRE_AI_Linux_User_Guide.pdf, then
use MFG Tools for programming NAND (or commands
given in profile "MX6Q-Sabreauto-NAND" in ucl2.xml.)
5 回复数
3,839 次查看
Hi Harris
it is in red colour attachment, please check my previous answer at 28.04.2016 5:38,
then click on red with mouse.
3,839 次查看
Harris
Many Thanks.
3,840 次查看
Hi Harris
3,839 次查看
Harris
Would you please give me the new_NAND support.pdf.
Thanks.
3,839 次查看
Harris
Hi, Igor,
Thank you for your reply.
hwo to get the new_NAND support.pdf?
Thanks.
