ota update kDownloadStateInitializationError
7,165 次查看
fx2020
Do full update use SystemUpdaterSample succeed.
But when i do  incremental update use SystemUpdaterSample, SystemUpdaterSample error.
the error code is kDownloadPayloadVerificationError. Do i Use the error system.img ?
5 回复数
7,123 次查看
fx2020
7,153 次查看
Zhiming_Liu
The normal process is like this:
1.Build first aosp image as user guide, flash this image to board.
2.change some files and make second image
3.make incremental between first and second image.
Do you make incremental packages like this?
Can you share your android log about this failure?
7,133 次查看
fx2020
flash to board use image in this location out/target/product/evk_8mq, flash succeed.
# make ota
make
target-files-package -j16
cp out/target/product/evk_8mq/obj/PACKAGING/target_files_intermediates/evk_8mq-target_files-eng.frank.zip ~/ota/nxp/evk_8mq-target_files-eng-A.frank.zip
# change some files
make target-files-package -j16
cp out/target/product/evk_8mq/obj/PACKAGING/target_files_intermediates/evk_8mq-target_files-eng.frank.zip ~/ota/nxp/evk_8mq-target_files-eng-B.frank.zip
./build/tools/releasetools/ota_from_target_files -i ~/ota/nxp/evk_8mq-target_files-eng-A.frank.zip ~/ota/nxp/evk_8mq-target_files-eng-B.frank.zip ~/ota/nxp/update.zip
Error info:
update_engine: [0913/085233.421711:ERROR:delta_performer.cc(1140)] Expected: sha256|hex = 685B998E4308F20FEA83D97E60222121FFE27983F013AED5C203709E139AE9DB
update_engine: [0913/085233.421760:ERROR:delta_performer.cc(1143)] Calculated: sha256|hex = B1025634138BF2B5378196E364350E1E5FCA126DEE0990A592290CEBFADC3F8B
Did i change the system.img ?
7,101 次查看
Zhiming_Liu
@fx2020
I have fixed this issue.
This issue may caused by such processs:
1.You flash images in out/
2.Then you make incremental-ota.zip to do ota
But this process is not correct.The hash value of system.img in out/ is different from  PREVIOUS-target_files.zip.
You need make otapackage to do  full update, this make sure that system.img's hash on board is same as PREVIOUS-target_files.zip.
Then do incremental update will always success.
7,103 次查看
Zhiming_Liu
I can reproduce same issue
