nxp 4.1.4 kernel
nxp 4.1.4 kernel
7,660件の閲覧回数
mihaitaivascu
   is there a 4.1.4 kernel from NXP and if so where do i get it from?
thanks,
     Mihaita
11 返答(返信)
5,943件の閲覧回数
gary_bisson
Senior Contributor III
Sorry I misread you the first time. In order to make up for my mistake, here is the new linux repo you should use:
https://source.codeaurora.org/external/imx/linux-imx
$ git clone https://source.codeaurora.org/external/imx/linux-imx -b imx_4.1.15_2.0.0_ga
Gary
5,943件の閲覧回数
mihaitaivascu
    I wonder why there is 4.6.7 kernel under https://source.codeaurora.org/external/imx/linux-imx if it has no support for imx families?
    I see under NXP webpage no 4.6.x kernel is listed for imx6ul ? Is this true? Any chance I could get a 4.6.x kernel with support for imx6ul already from somewhere else?
      Mihaita
5,943件の閲覧回数
Hi Mihaita
unfortunately 4.1.4 kernel not supported by NXP, supported kernels are described on
i.MX Software|NXP
5,943件の閲覧回数
mihaitaivascu
Hi Igor,
    I could not see the list of supported kernels, could you please forward me the exact link?
    I need a kernel older or the same as 4.1.4 with support for imx6ul . Does NXP has such a kernel?
         Mihaita
5,943件の閲覧回数
Hi  Mihaita
i.MX Software|NXP
linux-imx - i.MX Linux kernel
5,943件の閲覧回数
mihaitaivascu
Hello Igor,
    I tried to download 4.1.15 BSP for imx6ul from NXP but got an error.
    I have followed the instructions in the README. I have attched a log.
mivascu@ubuntu:~$ mkdir ~/bin
mivascu@ubuntu:~$ curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 27759 100 27759 0 0 84658 0 --:--:-- --:--:-- --:--:-- 84631
mivascu@ubuntu:~$ chmod a+x ~/bin/repo
mivascu@ubuntu:~$ PATH=${PATH}:~/bin
mivascu@ubuntu:~$ mkdir fsl-arm-yocto-bsp
mivascu@ubuntu:~$ cd fsl-arm-yocto-bsp
mivascu@ubuntu:~/fsl-arm-yocto-bsp$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1-krogoth
gpg: keyring `/home/mivascu/.repoconfig/gnupg/secring.gpg' created
gpg: keyring `/home/mivascu/.repoconfig/gnupg/pubring.gpg' created
gpg: /home/mivascu/.repoconfig/gnupg/trustdb.gpg: trustdb created
gpg: key 920F5C65: public key "Repo Maintainer <[email protected]>" imported
gpg: key 692B382C: public key "Conley Owens <[email protected]>" imported
gpg: Total number processed: 2
gpg: imported: 2 (RSA: 1)
Get https://gerrit.googlesource.com/git-repo/clone.bundle
remote: Finding sources: 100% (28/28)
remote: Total 28 (delta 8), reused 28 (delta 8)
Unpacking objects: 100% (28/28), done.
From https://gerrit.googlesource.com/git-repo
b3133a3..bd8f658 master -> origin/master
Get https://git.freescale.com/imx/fsl-arm-yocto-bsp.git
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
curl: (22) The requested URL returned error: 404 Not Found
Server does not provide clone.bundle; ignoring.
fatal: repository 'https://git.freescale.com/imx/fsl-arm-yocto-bsp.git/' not found
fatal: cannot obtain manifest git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
      Mihaita
5,943件の閲覧回数
mihaitaivascu
Hello Igor,
    If I try to get the kernel directly from your git i get the followinf error:
mivascu@ubuntu:~/kernel_source$ git clone git://git.freescale.com/imx/linux-imx.git
Cloning into 'linux-imx'...
fatal: repository 'https://git.freescale.com/imx/linux-imx.git/' not found
      Mihaita
5,943件の閲覧回数
Hi  Mihaita
for new issues please create new threads.
5,943件の閲覧回数
mihaitaivascu
Hi Igor,
     Thanks for the info .
     Do you know if NXP supports imx6ul architecture in 4.1.x or older kernels?
      Mihaita Ivascu
5,943件の閲覧回数
gary_bisson
Actually I'd say that there is a beta version of 4.14 kernel NXP:
https://source.codeaurora.org/external/imx/linux-imx/log/?h=imx_4.14.62_1.0.0_beta
Gary
5,943件の閲覧回数
mihaitaivascu
   Thanks for your reply but i am searching for 4.1.4 not 4.14
       Mihaita
