Hi, I am using IMX93 evk and trying to play .mp3 audio files but unable to play it.i am using mpg123 to play the files.but unable to hear sound from my headphones connected to J1201 audio jack.
If you want use mpg123 I suggest you check if let you chose which sound card is selected as output.
An alternative you could use is Gstreamer (the guide is for i.MX8 but also works on i.MX9).
Best regards.
