mmc0: Timeout waiting for hardware interrupt
3,906 次查看
vineethhegde
Hai...
I am using i.MX6Q based board. Schematics is similar to the Sabre SD board. i got a error message as shown below.
Please suggest a solution.
2,021 次查看
igorpadykov
Hi vineeth113
seems sd port is not working correctly. Since you are using customizing BSP,
recommended to test board with Freescale BSP or with SDK. Also check signals
with oscilloscope, connecting to port sd card.
