mfgtool
mfgtool
rakesh3
Contributor V
I am using the latest mfgtool called UUU tool to flash the image into the imx6 device. But while using the cmd for flashing the u-boot into device
Below command worked fine and given successful.
<.\uuu.exe SDP: dcd -f u-boot.imx
But next command hangs and showing this error .
SDPU: write -f imx-boot-imx8mmevk-sd.bin-flash_evk -offset 0x57c00
what could be the possible issue in this..
Could someone help me out in this .
Rakesh
