lvds no display
lvds no display
1,578 次查看
shishui
imx6d at linux3.0.35 Run for a period of time will appear no display,os running  normal. lcd screen size is 1920*720.
What might be the reason?
thank you.!
1,489 次查看
shishui
Hi Bio,
yes,  How do I view the actions that caused the proble,such as gpu register and so on.
because reconfig gpu recover display.
thank you.!
1,489 次查看
Bio_TICFSL
Hi Shi,
Unfortunately you are playing with an old version of the BSP, you can check the Linux
Reference Manual, and do the LVDS unit test in order to avoid any problem.
regards
