kernel crashes while bootup-imx6q-v1.1
ソリューションへジャンプ
2,857件の閲覧回数
ManoharChinnadu
Hi All,
Here we are working on board bringup activity and now kernel randomly crashes(in different functions) while booting kernel.
we are using imx6q processor version is 1.1.
did anyone faced the similar issue or by looking into logs can you comment what might be the issue.
Thanks in advance....
Original Attachment has been moved to: imx6_failed_log_1.txt.zip
Original Attachment has been moved to: imx6_failed_log_3.txt.zip
Original Attachment has been moved to: imx6_failed_log_2.txt.zip
Original Attachment has been moved to: imx6_failed_log_4.txt.zip
ラベル(5)
2,380件の閲覧回数
Jon1z
I just found out that 13.3 BSPs and images are for REV B sabresd boards (in release notes) check your reference board revision...
2 返答(返信)
2,381件の閲覧回数
Jon1z
2,380件の閲覧回数
Jon1z
     I am also facing the same problems when booting from eMMC using the prebuilt 13.3 images. The board keeps on rebooting agin and again. I am using the imx6q sabresd dev board.
Have you resolved this? I posted the same thing here: https://community.nxp.com/thread/302864
and yeah we have the same logs. I also posted the log using 13.4 prebuilt images, which boots fine...
edit: my board revision is SCH-27392 Rev C1 (sticker is below the boot switch)
the sticker on top says MXIMX6q-SDP.
the sticker below the GPS antenna is 700-27392
