imxv4l2src pad capabilities
1,178 次查看
paul_stn
What are the exact pad capabilities for "imxv4l2src" ? The gst-inspect doesn't show any capabilities.Is there any document for this plugin?
标签 (2)
1 回复
1,151 次查看
AldoG
which command did you try with?
gst-inspect-1.0 imxv4l2src should output all information.
Also, could you share which kernel version are you trying with?
Aldo.
