imx95 npu support
imx95 npu support
2,641 次查看
nigelzzz
   We are using imx95 develop some machine learning app. so I need some sample code and doc to check npu performance and learn how to use the npu to calculate complex operation.
first question:
I reference the document from nxp, it says we can use "label_image" to check the performance on npu and cpu.
-  npu version: ./label_image -m mobilenet_v1_1.0_224_quant.tflite -i grace_hopper.bmp -l labels.txt --external_delegate_path=/usr/lib/libneutron_delegate.so
- cpu version: ./label_image -m mobilenet_v1_1.0_224_quant.tflite -i grace_hopper.bmp -l labels.txt .
the average time always return 16.xxx ms, why it doesn't improve when i using npu.
INFO: Loaded model mobilenet_v1_1.0_224_quant.tflite
INFO: resolved reporter
INFO: invoked
INFO: average time: 16.558 ms
INFO: 0.764706: 653 military uniform
INFO: 0.121569: 907 Windsor tie
INFO: 0.0156863: 458 bow tie
INFO: 0.0117647: 466 bulletproof vest
INFO: 0.00784314: 835 suit
the second question is i see /usr/lib/libneutron_delegate.so can load "NeutronKernels.bin and NeutronFirmware.elf", can we get the source code?
reference document
- https://www.nxp.com/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf
- https://github.com/nxp-imx/neutron
- https://github.com/nxp-imx/tflite-neutron-delegate
标记 (1)
2,618 次查看
Chavira
Hi @nigelzzz!
Thank you for contacting NXP Support!
Sorry, we can´t provide the source code of those binaries.
The iMX95 is not available for all.
To get support I recommend to ask directly to your local DFAE.
Sorry for the mistake!
Best Regards!
Chavira
2,605 次查看
nigelzzz
   Do you have any suggestion on how to check the npu on imx95 is work.
I see we can use label_image to check performance on npu/gpu/cpu.
Does the imx95 have similiar tool to check?
