imx91 MAC fuse programming in linux shell
6,962 次查看
Robbi
Hi Team,
I'm able to burn MAC OTP using fuse prog -y command in u-boot terminal. But I need to run a bash script in Linux shell post booting and during that script execution it will ask for user to enter MAC address in command line interface so I had checked OCOTP, which is not available in /sys/bus/nvmem/devices/ (I had enabled NVMEM configurations and OCOTP node in kernel device tree) but I need some guidance or commands to proceed.
标记 (1)
12 回复数
6,922 次查看
joanxie
6,920 次查看
Robbi
I'm getting access denied please provide me access.
6,910 次查看
joanxie
I sent mail to you, pls check
6,905 次查看
Robbi
Thank for support
6,867 次查看
Robbi
Hi Team,
As MAC OTP is irreversible process, please verify below command which I'm using to perform MAC OTP.
Note: Our custom board has one ethernet port(i.e. eth1)
Write commands in Uboot terminal:
Consider MAC as 0xAABBCCDDEEFF(6Bytes)
fuse prog -y 39 3 0xCCDDEEFF
fuse prog -y 39 4 0x0000AABB
Read commands in Uboot terminal:
fuse read  39 3
fuse read  39 4
I had referred "i.MX91_Fusemap_RM.xlsx" excel sheet attached to reference manual.
And is there any other source like Reference Manual  to confirm the register other than this excel sheet. Waiting for response.
Thank you
Manikanta Robbi
6,695 次查看
joanxie
the fusemap you refer to is correct, we don't have other fusemap, you can refer to this xlsx files
6,606 次查看
Robbi
Hi @joanxie
Thanks for the quick response.
I have reviewed the shared "fuse_read_write_test.c" and associated references. However, enabled OCOTP node in kernel device tree and required configuration and modified register bank address and offset in the code but unable to successfully program the MAC address fuse from Linux using the provided source file. Using the above code, I was able to read but not able to the fuse does not update the MAC value in the NVMEM region. Kindly find the attached image for reference.
  1. Is it possible to perform OTP via linux shell(not using u-boot)
  2. if yes, what are the necessary configurations that need to be done to enable write operation.
  3. Share if any references.
6,267 次查看
joanxie
reading and writing via nvmem is what you need, did you apply the patches I sent to you? do you mean you can read the nvmem correctly, but write failed? any error message?
6,261 次查看
Robbi
yes joanxie, Thanks for the support I'm using older kernel version (6.6.52) earlier and upgraded to (6.12.46) now the commands are executing successfully.
6,135 次查看
joanxie
great, glad to hear this!
5,992 次查看
Robbi
Hi @joanxie
I has successfully performed  MAC OTP (00:50:F9:27:72:1B) using below commands in  linux kernel version-6.12.48
  1. echo -n -e "\x1B\x72\x27\xF9" > /tmp/fuse.bin
  2. dd if=/tmp/fuse.bin of=/sys/bus/nvmem/devices/fsb_s400_fuse1/nvmem bs=4 seek=315 conv=notrunc
  3. echo -n -e "\x50\x00\x00\x00" > /tmp/fuse.bin
  4. dd if=/tmp/fuse.bin of=/sys/bus/nvmem/devices/fsb_s400_fuse1/nvmem bs=4 seek=316 conv=notrunc
    verified with reading register using hexdump and fuse read commands.
    root@imx:~# hexdump -Cv -s 0x4ec -n 6 /sys/bus/nvmem/devices/fsb_s400_fuse1/nvmem
    000004ec 1b 72 27 f9 50 00 |.r'.P.|
    000004f2
    But I'm not getting fused MAC address while I'm using "ifconfig" command, it is displaying random MAC address.(During boot time also). Please find the attached ZIP file contains  ETH kernel device tree node and all relevant images. Guide me to resolve this issue, if I miss enabling any configurations or did I fused correctly registers(Based on Bank and word).
5,690 次查看
joanxie
sorry there are some issues with community, I missed your message before, do you mind sharing your fuse command result by fuse prog and nvmem dump result?
%3CLINGO-SUB%20id%3D%22lingo-sub-2326434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx91%20%E5%9C%A8%20Linux%20%E5%A4%96%E5%A3%B3%E4%B8%AD%E7%BC%96%E7%A8%8B%20MAC%20%E7%86%94%E4%B8%9D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%83%BD%E5%A4%9F%E5%9C%A8%20u-%E5%90%AF%E5%8A%A8%20%E7%BB%88%E7%AB%AF%E4%B8%AD%E4%BD%BF%E7%94%A8%20%E7%86%94%E4%B8%9D%20prog-y%20%E5%91%BD%E4%BB%A4%E7%83%A7%E5%BD%95%20MAC%20OTP%E3%80%82%E4%BD%86%E6%98%AF%E5%90%AF%E5%8A%A8%E5%90%8E%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%20Linux%20shell%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E4%B8%80%E4%B8%AA%20bash%20%E8%84%9A%E6%9C%AC%EF%BC%8C%E5%9C%A8%E8%84%9A%E6%9C%AC%E6%89%A7%E8%A1%8C%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E5%AE%83%E4%BC%9A%E8%A6%81%E6%B1%82%E7%94%A8%E6%88%B7%E5%9C%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%95%8C%E9%9D%A2%E4%B8%AD%E8%BE%93%E5%85%A5%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20OCOTP%EF%BC%8C%E5%AE%83%E5%9C%A8%20%2Fsys%2Fbus%2Fnvmem%2Fdevices%2F%20%E4%B8%AD%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%88%E6%88%91%E5%9C%A8%E5%86%85%E6%A0%B8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E5%90%AF%E7%94%A8%E4%BA%86%20NVMEM%20%E9%85%8D%E7%BD%AE%E5%92%8C%20OCOTP%20%E8%8A%82%E7%82%B9%EF%BC%89%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E6%8C%87%E5%AF%BC%E6%88%96%E5%91%BD%E4%BB%A4%E6%89%8D%E8%83%BD%E7%BB%A7%E7%BB%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%BB%99%E6%82%A8%E5%8F%91%E4%BA%86%E9%82%AE%E4%BB%B6%EF%BC%8C%E8%AF%B7%E6%9F%A5%E6%94%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E8%A2%AB%E6%8B%92%E7%BB%9D%EF%BC%8C%E8%AF%B7%E4%B8%BA%E6%88%91%E6%8F%90%E4%BE%9B%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%AD%A4%E9%93%BE%E6%8E%A5%3C%2FP%3E%0A%3CP%3Eh%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecurity-Blog-NXP-Internal%2FHow-to-fuse-key-through-nvmem-on-i-MX93%2Fta-p%2F165727%22%20target%3D%22_blank%22%3Ettps%3A%2F%2F%3C%2FA%3Ecommunity.nxp.com%2Ft5%2FSecurity-Blog-NXP-Internal%2FHow-to-fuse-key-through-nvmem-on-i-MX93%2Fta-p%2F1657278%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%94%AF%E6%8C%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20MAC%20OTP%20%E6%98%AF%E4%B8%8D%E5%8F%AF%E9%80%86%E7%9A%84%E8%BF%9B%E7%A8%8B%EF%BC%8C%E8%AF%B7%E9%AA%8C%E8%AF%81%E6%88%91%E7%94%A8%E6%9D%A5%E6%89%A7%E8%A1%8C%20MAC%20OTP%20%E7%9A%84%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%88%91%E4%BB%AC%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E6%9C%89%E4%B8%80%E4%B8%AA%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%EF%BC%88%E5%8D%B3eth1)%3C%2FP%3E%3CP%3E%E5%9C%A8%20Uboot%20%E7%BB%88%E7%AB%AF%E4%B8%AD%E5%86%99%E5%85%A5%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%B0%86%20MAC%20%E8%A7%86%E4%B8%BA%200xAABBCCDDEEFF%EF%BC%886%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%86%94%E4%B8%9D%20prog-y%2039%203%200xccddeeff%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%86%94%E4%B8%9D%20prog-y%2039%204%200x0000AABB%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20Uboot%20%E7%BB%88%E7%AB%AF%E4%B8%AD%20READ%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%86%94%E4%B8%9D%E8%AF%BB%E5%8F%96%2039%203%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%86%94%E4%B8%9D%E8%AF%BB%E5%8F%96%2039%204%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%82%E8%80%83%E4%BA%86%22i.MX91_Fusemap_RM.xlsx%22excel%20%E8%A1%A8%E9%99%84%E5%9C%A8%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%E9%99%A4%E4%BA%86%E8%BF%99%E5%BC%A0excel%E8%A1%A8%E6%A0%BC%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%9D%A5%E6%BA%90%EF%BC%88%E4%BE%8B%E5%A6%82%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%89%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%E6%B3%A8%E5%86%8C%E5%90%97%EF%BC%9F%E7%AD%89%E5%BE%85%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CP%3E%E9%A9%AC%E5%B0%BC%E5%9D%8E%E5%A1%94-%E7%BD%97%E6%AF%94%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%20fusemap%20%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%20fusemap%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%AD%A4%20xlsx%20%E6%96%87%E4%BB%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9F%A5%E7%9C%8B%E4%BA%86%E5%85%B1%E4%BA%AB%E7%9A%84%20%22%20fuse_read_write_test.c%20%22%20%E5%92%8C%E7%9B%B8%E5%85%B3%E7%9A%84%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E5%86%85%E6%A0%B8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E5%90%AF%E7%94%A8%E4%BA%86%20OCOTP%20%E8%8A%82%E7%82%B9%EF%BC%8C%E9%9C%80%E8%A6%81%E9%85%8D%E7%BD%AE%E5%B9%B6%E4%BF%AE%E6%94%B9%E4%BA%86%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E5%BA%93%E5%9C%B0%E5%9D%80%E5%92%8C%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%E6%88%90%E5%8A%9F%E7%BC%96%E7%A8%8B%20Linux%20%E4%B8%AD%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%E7%86%94%E4%B8%9D%E3%80%82%E4%BD%BF%E7%94%A8%E4%B8%8A%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E8%AF%BB%E5%8F%96%E4%BD%86%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E7%86%94%E4%B8%9D%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%20NVMEM%20%E5%8C%BA%E5%9F%9F%E4%B8%AD%E7%9A%84%20MAC%20%E5%80%BC%E3%80%82%E8%AF%B7%E6%9F%A5%E7%9C%8B%E6%89%80%E9%99%84%E5%9B%BE%E7%89%87%E4%BB%A5%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FDIV%3E%3COL%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E9%80%9A%E8%BF%87%20linux%20shell%20%E6%89%A7%E8%A1%8C%20OTP%EF%BC%88%E4%B8%8D%E4%BD%BF%E7%94%A8%20u-boot%EF%BC%89%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%8C%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E5%93%AA%E4%BA%9B%E5%BF%85%E8%A6%81%E9%85%8D%E7%BD%AE%E6%89%8D%E8%83%BD%E8%BF%9B%E8%A1%8C%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%82%E8%80%83%EF%BC%8C%E8%AF%B7%E5%88%86%E4%BA%AB%E3%80%82%3C%2FDIV%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%98%AF%E7%9A%84%EF%BC%8Cjoanxie%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E8%BE%83%E6%97%A9%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%EF%BC%886.6.52%EF%BC%89%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%8D%87%E7%BA%A7%E5%88%B0%E4%BA%86%EF%BC%886.12.46%EF%BC%89%EF%BC%8C%E5%91%BD%E4%BB%A4%E6%89%A7%E8%A1%8C%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%80%9A%E8%BF%87%20nvmem%20%E8%AF%BB%E5%8F%96%E5%92%8C%E5%86%99%E5%85%A5%E6%98%AF%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%BA%94%E7%94%A8%E4%BA%86%E6%88%91%E5%8F%91%E9%80%81%E7%BB%99%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%9F%20%E6%82%A8%E6%98%AF%E8%AF%B4%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E8%AF%BB%E5%8F%96%20nvmem%EF%BC%8C%E4%BD%86%E5%86%99%E5%85%A5%E5%A4%B1%E8%B4%A5%EF%BC%9F%E6%9C%89%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%AA%E5%A5%BD%E4%BA%86%EF%BC%8C%E5%BE%88%E9%AB%98%E5%85%B4%E5%90%AC%E5%88%B0%E8%BF%99%E4%B8%AA%E6%B6%88%E6%81%AF%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%20%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E5%9C%A8%20linux%20%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC-6.12.48%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%88%90%E5%8A%9F%E6%89%A7%E8%A1%8C%E4%BA%86%20MAC%20OTP%3CSTRONG%3E(00%3A50%3AF9%3A27%3A72%3A1B%3C%2FSTRONG%3E)%20%3C%2FP%3E%3COL%3E%3CLI%3Eecho-n-e%20%22%5C%20x1b%5C%20x72%5C%20x27%5C%20xF9%20%22%20%26gt%3B%20%2Ftmp%2F%E7%86%94%E4%B8%9D.bin%3C%2FLI%3E%3CLI%3Edd%20if%3D%2Ftmp%2F%E7%86%94%E4%B8%9D.bin%20of%3D%2Fsys%2Fbus%2Fnvmem%2F%E8%AE%BE%E5%A4%87%2Ffsb_s400_%E7%86%94%E4%B8%9D1%2Fnvmem%20bs%3D4%20seek%3D315%20conv%3Dnotrunc%3C%2FLI%3E%3CLI%3Eecho-n-e%20%22%5C%20x50%5C%20x00%5C%20x00%5C%20x00%20%22%20%26gt%3B%20%2Ftmp%2Ffuse.bin%3C%2FLI%3E%3CLI%3Edd%20if%3D%2Ftmp%2F%E7%86%94%E4%B8%9D.bin%20of%3D%2Fsys%2Fbus%2Fnvmem%2Fdevices%2Ffsb_s400_%E7%86%94%E4%B8%9D1%2Fnvmem%20bs%3D4%20seek%3D316%20conv%3Dnotrunc%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E8%BD%AC%E5%82%A8%E5%92%8C%E7%86%94%E4%B8%9D%E8%AF%BB%E5%8F%96%E5%91%BD%E4%BB%A4%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%AA%8C%E8%AF%81%E3%80%82%3CBR%20%2F%3Eroot%20%40imx%EF%BC%9A~%23%20hexdump-Cv-s%200x4ec-n%206%20%2Fsys%2Fbus%2Fnvmem%2Fdevices%2Ffsb_s400_fuse1%2Fnvmem%3CBR%20%2F%3E%20000004ec%201b%2072%2027%20f9%2050%2000%20%7C.r'.p.%7C%3CBR%20%2F%3E%20000004f2%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E4%BD%86%E6%98%AF%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20%22%3CSTRONG%3E%20ifconfig%3C%2FSTRONG%3E%20%22%20%E5%91%BD%E4%BB%A4%E6%97%B6%E6%B2%A1%E6%9C%89%E5%BE%97%E5%88%B0%E7%86%94%E4%B8%9D%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E7%9A%84%E6%98%AF%E9%9A%8F%E6%9C%BA%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%E3%80%82%20%EF%BC%88%E6%9C%9F%E9%97%B4%E5%90%AF%E5%8A%A8%E6%97%B6%E9%97%B4%E4%B9%9F%E6%98%AF%E5%A6%82%E6%AD%A4%EF%BC%89%E3%80%82%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%9A%8F%E9%99%84%E7%9A%84%20ZIP%20%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%20ETH%20%E5%86%85%E6%A0%B8%E8%AE%BE%E5%A4%87%E6%A0%91%E8%8A%82%E7%82%B9%E5%92%8C%E6%89%80%E6%9C%89%E7%9B%B8%E5%85%B3%E6%98%A0%E5%83%8F%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E9%94%99%E8%BF%87%E4%BA%86%E5%90%AF%E7%94%A8%E4%BB%BB%E4%BD%95%E9%85%8D%E7%BD%AE%E6%88%96%E8%80%85%E6%88%91%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%9C%B0%E7%86%94%E4%B8%9D%E4%BA%86%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88%E5%9F%BA%E4%BA%8E%E9%93%B6%E8%A1%8C%E5%92%8C%E6%96%87%E5%AD%97%EF%BC%89%EF%BC%8C%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2335217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx91%20MAC%20fuse%20programming%20in%20linux%20shell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8A%B1%E6%AD%89%E7%A4%BE%E5%8C%BA%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%B9%8B%E5%89%8D%E9%94%99%E8%BF%87%E4%BA%86%E4%BD%A0%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%8C%E4%BD%A0%E4%BB%8B%E6%84%8F%E9%80%9A%E8%BF%87%20%E7%86%94%E4%B8%9D%20prog%20%E5%92%8C%20nvmem%20%E8%BD%AC%E5%82%A8%E7%BB%93%E6%9E%9C%E5%88%86%E4%BA%AB%E4%BD%A0%E7%9A%84%20%E7%86%94%E4%B8%9D%20%E5%91%BD%E4%BB%A4%E7%BB%93%E6%9E%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
