Hi all,
I have a new problem. Can you help me?
I am trying to work imx8qx's sai0 output. At software side everything looks fine. But I cannot any signal sai0's output with oscilloscope. My working stages at below.
Then I configure my device-tree :
sound {
compatible = "simple-audio-card";
simple-audio-card,bitclock-master = <&dailink_master>;
simple-audio-card,format = "i2s";
simple-audio-card,frame-master = <&dailink_master>;
simple-audio-card,name = "tas2770-Audio";
dailink_master: simple-audio-card,codec {
sound-dai = <&codec>;
clocks = <&mclkout0_lpcg 0>;
cpusai: simple-audio-card,cpu {
sound-dai = <&sai0>;
dai-tdm-slot-num = <2>;
dai-tdm-slot-width = <32>;
&i2c1 {
codec: tas2770@41 {
compatible = "ti,tas2770";
#sound-dai-cells = <0>;
assigned-clocks = <&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_PLL>,
<&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_SLV_BUS>,
<&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_MST_BUS>,
<&mclkout0_lpcg 0>;
assigned-clock-rates = <786432000>, <49152000>, <12000000>, <12000000>;
clock-names = "mclk";
reg = <0x41>;
ti,asi-format = <0>;
ti,left-slot = <0>;
ti,right-slot = <1>;
ti,imon-slot-no = <0>;
ti,vmon-slot-no = <2>;
#address-cells = <1>;
#size-cells = <0>;
ti,reset-gpio = <&portexp 19 GPIO_ACTIVE_LOW>;
ti,irq-gpio = <&lsio_gpio3 0 GPIO_ACTIVE_LOW>;
&sai0 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_sai0>;
status = "okay";
fsl,sai-asynchronous;
pinctrl_sai0: sai0grp {
fsl,pins = <
IMX8QXP_SPI0_SDI_ADMA_SAI0_TXD 0x06000040
IMX8QXP_SPI0_SCK_ADMA_SAI0_TXC 0x06000040
IMX8QXP_SPI0_SDO_ADMA_SAI0_TXFS 0x06000040
@@ -252,6 +252,20 @@ void board_init(boot_phase_t phase)
/* Configure SNVS button timing (ON->OFF 5s, OFF->ON 100ms) */
SNVS_ButtonTime(SNVS_DRV_BTN_ON_100MS, SNVS_DRV_BTN_DEBOUNCE_100MS, SNVS_DRV_BTN_PRESS_5S);
+ pad_force_mux(SC_P_SPI0_SDO, 1, SC_PAD_CONFIG_OUT_IN,
+ SC_PAD_ISO_OFF);
+ pad_force_mux(SC_P_SPI0_SCK, 1, SC_PAD_CONFIG_OUT_IN,
+ SC_PAD_ISO_OFF);
+ pad_force_mux(SC_P_SPI0_SDI, 1, SC_PAD_CONFIG_OUT_IN,
+ SC_PAD_ISO_OFF);
+ pad_force_mux(SC_P_SPI0_CS0, 1, SC_PAD_CONFIG_OUT_IN,
+ SC_PAD_ISO_OFF);
+ board_print(3, "%s(BOOT_PHASE_FINAL_INIT SAI pins configurated - %u)\n", __func__, (unsigned)phase);
break;
case BOOT_PHASE_TEST_INIT: /* Init HW required for unit tests */
board_print(3, "%s(BOOT_PHASE_TEST_INIT - %u)\n", __func__, (unsigned)phase);
root@tqma8xqp-mba8xx:~# dmesg | grep tas27
[ 2.219460] tas2770 16-0041: tas2770_i2c_probe enter
[ 2.224527] tas2770 16-0041: ti,asi-format=0
[ 2.224551] tas2770 16-0041: ti,reset-gpio=507
[ 2.224568] tas2770 16-0041: ti,irq-gpio=96
[ 2.224574] tas2770 16-0041: ti,left-slot=0
[ 2.224580] tas2770 16-0041: ti,right-slot=1
[ 2.224586] tas2770 16-0041: ti,imon-slot-no=0
[ 2.224592] tas2770 16-0041: ti,vmon-slot-no=2
[ 2.224610] tas2770 16-0041: irq = 233
[ 2.261280] tas2770 16-0041: tas2770_register_codec, enter
[ 3.716892] tas2770 16-0041: tas2770_codec_probe
[ 3.721583] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0xa
[ 3.721593] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0xa
[ 3.721602] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0xa
[ 3.721610] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0xa
[ 3.721623] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 3.721632] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 3.721641] debugfs: Directory '59040000.sai' with parent 'tas2770-Audio' already present!
[ 3.729954] tas2770 16-0041: tas2770_set_dai_fmt, format=0x1001
[ 3.729960] tas2770 16-0041: ASI format master is not found
[ 3.735543] tas2770 16-0041: INV format: NBNF
[ 3.735551] tas2770 16-0041: tas2770_codec_read, reg: 0xb, value: 0x2
[ 3.735558] tas2770 16-0041: tas2770_codec_read, reg: 0xb, value: 0x2
[ 3.735565] tas2770 16-0041: tas2770_codec_read, reg: 0xd, value: 0x10
[ 3.735571] tas2770 16-0041: tas2770_codec_read, reg: 0xd, value: 0x10
[ 3.735578] tas2770 16-0041: tas2770_codec_read, reg: 0xd, value: 0x10
[ 3.735583] tas2770 16-0041: slot value: 0x10
[ 3.735667] asoc-simple-card sound: tas2770 ASI1 <-> 59040000.sai mapping ok
[ 3.748553] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 3.748584] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 4.114813] #0: tas2770-Audio
[ 8.532424] tas2770 16-0041: tas2770_codec_read, reg: 0x3, value: 0x10
[ 8.537366] tas2770 16-0041: tas2770_codec_write, reg: 0x3, 0x14
[ 8.537509] tas2770 16-0041: tas2770_codec_read, reg: 0x5, value: 0x0
[ 8.537546] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0xa
[ 8.537573] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0xa
[ 8.537880] tas2770 16-0041: tas2770_codec_write, reg: 0xc, 0x1a
[ 8.537923] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 8.537956] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 8.599187] tas2770 16-0041: tas2770_codec_read, reg: 0x3, value: 0x14
[ 8.599235] tas2770 16-0041: tas2770_codec_read, reg: 0x5, value: 0x0
[ 8.599266] tas2770 16-0041: tas2770_codec_read, reg: 0xc, value: 0x1a
[ 8.599290] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
[ 8.599313] tas2770 16-0041: tas2770_codec_read, reg: 0x2, value: 0xe
root@tqma8xqp-mba8xx:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=tas2770Audio
tas2770-Audio,
Default Audio Device
usbstream:CARD=tas2770Audio
tas2770-Audio
USB Stream Output
root@tqma8xqp-mba8xx:~# speaker-test
speaker-test 1.1.9
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 3840 to 5760
Period size range from 1920 to 1920
Using max buf[f e r20 s7i.z7e6 09577610]
tPaesr27i7od0s 1=6- 400
4w1a:s isrqet_ wpoerrki_ordou_stiiznee
= 1920
was set buffer_size = 5760
0 - Front Left
[ 207.775724] tas2770 16-0041: IRQ status : 0x4, 0x0
I cannot see any digital signal at my som's sai0 pins via oscilloscope.
I wam waiting for your helps.
Thanks.
已解决! 转到解答。
Hi yildizberat
one can look at wm8960 example
and Figure 27. ALSA SoC Software Architecture i.MX Linux Reference Manual
I think I have the same problem:
On a custom board I'm using a really simple codec (sgtl5000), connected via sai0 to an imx8qxp soc.
My audio codec plays well with 4.19 kernel, but with Yocto kernel 5.4.70 I can't see any signal (clock and data) on I2S bus.
At boot my codec is correctly recognized and linked to the sai0 controller.
With 5.4 kernel I can run "aplay test.vaw", but using the scope I can't see any signal at all.
Can you please clarify what have you correct in your machine driver ?
Really many thanks in advance.
Giuseppe
Hi yildizberat
