[imx8qmmek][rpmsg][remoteproc] remoteproc and rpmsg fail.
3,563 次查看
WolsYang
I am trying to do remoteproc and rpmsg with i.MX 8QMax MEK Linux Binary Demo files and i.MX Yocto Project User's Guide, Rev. LF5.10.72_2.2.0, 17 December 2021.
My M4 image is come from Demo files/imx_mcore_demos/imx8qm_m4_TCM_hello_world_m40.bin &
i.MX8QM-MEK-MCUSDK/m4/boards/mekmimx8qm/multicore_examples/rpmsg_lite_str_echo_rtos/cm4_core0/armgcc/debug/rpmsg_lite_str_echo_rtos_imxcm4_m40.elf
And Linux image comming from Yocto version is 5.10.72-lts-5.10.y+ga68e31b63f86 :
$ DISTRO=fsl-imx-wayland MACHINE=imx8qmmek source  imx-setup-release.sh -b build
$ bitbake imx-image-full
When I power on, M4 print hello world and keep go into Linux shell..
Then I do modprobe imx_rpmsg_tty and fail
root@imx8qmmek:~# modprobe imx_rpmsg_tty
modprobe: FATAL: Module imx_rpmsg_tty not found in directory /lib/modules/5.10.72-lts-5.10.y+ga68e31b63f86
Change M4 firmware through remotproc also fail
root@imx8qmmek:~# cd /lib/firmware/
root@imx8qmmek:/lib/firmware# echo rpmsg_lite_str_echo_rtos_imxcm4_m40.elf > /sys/class/remoteproc/remoteproc0/firmware
root@imx8qmmek:/lib/firmware# cat /sys/class/remoteproc/remoteproc0/firmware
root@imx8qmmek:/lib/firmware# cat /sys/class/remoteproc/remoteproc0/state
offline
root@imx8qmmek:/lib/firmware# echo start > /sys/class/remoteproc/remoteproc0/state
[  869.481128] remoteproc remoteproc0: powering up imx-dsp-rproc
[  869.494189] remoteproc remoteproc0: Booting fw image rpmsg_lite_str_echo_rtos_imxcm4_m40.elf, size 512636
[  869.544564] remoteproc remoteproc0: Registered carveout doesn't fit da request
[  869.551943] remoteproc remoteproc0: Failed to process resources: -12
[  869.558636] remoteproc remoteproc0: Boot failed: -12
-sh: echo: write error: Cannot allocate memory
This is dts I am use showing in uboot(u-boot => printenv).
fdt_file=imx8qm-mek-rpmsg.dtb
Also I check the kernel config, it is already turn on rpmsg:
root@imx8qmmek:/lib/firmware# uname -r
root@imx8qmmek:/lib/firmware# zcat /proc/config.gz | grep -i rpmsg
CONFIG_KEYBOARD_RPMSG=y
CONFIG_GPIO_IMX_RPMSG=y
# CONFIG_REGULATOR_PF1550_RPMSG is not set
CONFIG_SND_SOC_FSL_RPMSG=y
CONFIG_SND_SOC_IMX_AUDIO_RPMSG=y
CONFIG_SND_SOC_IMX_PCM_RPMSG=y
CONFIG_SND_SOC_IMX_RPMSG=y
CONFIG_SND_SOC_RPMSG_WM8960=y
CONFIG_SND_SOC_RPMSG_WM8960_I2C=y
CONFIG_SND_SOC_RPMSG_AK4497=y
CONFIG_RTC_DRV_IMX_RPMSG=y
# CONFIG_CROS_EC_RPMSG is not set
# Rpmsg drivers
CONFIG_RPMSG=y
CONFIG_RPMSG_CHAR=y
CONFIG_RPMSG_CTRL=y
CONFIG_RPMSG_NS=y
CONFIG_RPMSG_QCOM_GLINK=y
CONFIG_RPMSG_QCOM_GLINK_RPM=y
CONFIG_RPMSG_VIRTIO=y
CONFIG_HAVE_IMX_RPMSG=y
CONFIG_IMX_RPMSG_PINGPONG=m
CONFIG_IMX_RPMSG_TTY=m
# end of Rpmsg drivers
CONFIG_RPMSG_LIFE_CYCLE=y
3 回复数
1,234 次查看
bhupiister
@WolsYang were you able to solve the second issue?
1,226 次查看
WolsYang
No
We didn't follow up this function
3,539 次查看
WolsYang
To fix the missing imx_rpmsg_tty kernel module error :
Add this line to your layer.conf.
IMAGE_INSTALL_append = "kernel-modules"
I think kernel modules should install automatically, but now just add it and fix the problem : )
The remoteproc still falling hopefully got good news soon : (
%3CLINGO-SUB%20id%3D%22lingo-sub-1400571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5Bimx8qmmek%5D%5Brpmsg%5D%5Bremoteproc%5D%20remoteproc%20%E5%92%8C%20rpmsg%20%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1400571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20i.M%20%3CSPAN%3EX%208QMax%20MEK%20Linux%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%BC%94%E7%A4%BA%E6%96%87%E4%BB%B6%E5%92%8C%20i.MX%20Yocto%20Project%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%20LF5.10.72_2.2.0%EF%BC%8C2021%20%E5%B9%B4%2012%20%E6%9C%88%2017%20%E6%97%A5%EF%BC%89%E6%9D%A5%E5%81%9A%20remoteproc%20%E5%92%8C%3C%2FSPAN%3E%20rpmsg%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%9A%84%20M4%20%E6%98%A0%E5%83%8F%E6%9D%A5%E8%87%AA%20Demo%20files%2Fimx_mcore_demos%2Fimx8qm_m4_TCM_hello_world_m40.bin%26amp%3B%20%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ei.MX8QM-MEK-MCUSDK%2Fm4%2Fboards%2Fmekmimx8qm%2Fmulticore_examples%2Frpmsg_lite_str_echo_rtos%2Fcm4_core0%2Farmgcc%2Fdebug%2Frpmsg_lite_str_echo_rtos_imxcm4_m40.elf%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9D%A5%E8%87%AA%20Yocto%20%E7%89%88%E6%9C%AC%E7%9A%84%20Linux%20%E6%98%A0%E5%83%8F%E6%98%AF%205.10.72-lts-5.10.y%2Bga68e31b63f86%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20DISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8qmmek%20source%20%20imx-setup-release.sh%20-b%20build%0A%24%20bitbake%20imx-image-full%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%BC%80%E6%9C%BA%E6%97%B6%EF%BC%8CM4%20%E6%89%93%E5%8D%B0%20hello%20world%20%E5%B9%B6%E7%BB%A7%E7%BB%AD%E8%BF%9B%E5%85%A5%20Linux%20shell%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E6%89%A7%E8%A1%8C%20modprobe%20imx_rpmsg_tty%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%98%AF%20%3CFONT%20size%3D%225%22%3E%3CSTRONG%3E%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8qmmek%3A~%23%20modprobe%20imx_rpmsg_tty%0Amodprobe%3A%20FATAL%3A%20Module%20imx_rpmsg_tty%20not%20found%20in%20directory%20%2Flib%2Fmodules%2F5.10.72-lts-5.10.y%2Bga68e31b63f86%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%98%E5%8F%AF%E9%80%9A%E8%BF%87%E8%BF%9C%E7%A8%8B%E7%A8%8B%E5%BA%8F%E6%9B%B4%E6%94%B9%20M4%20%E5%9B%BA%E4%BB%B6%20%3CFONT%20size%3D%225%22%3E%3CSTRONG%3E%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8qmmek%3A~%23%20cd%20%2Flib%2Ffirmware%2F%0Aroot%40imx8qmmek%3A%2Flib%2Ffirmware%23%20echo%20rpmsg_lite_str_echo_rtos_imxcm4_m40.elf%20%26gt%3B%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Ffirmware%20%0Aroot%40imx8qmmek%3A%2Flib%2Ffirmware%23%20cat%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Ffirmware%20%0Arpmsg_lite_str_echo_rtos_imxcm4_m40.elf%0Aroot%40imx8qmmek%3A%2Flib%2Ffirmware%23%20cat%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%20%0Aoffline%0Aroot%40imx8qmmek%3A%2Flib%2Ffirmware%23%20echo%20start%20%26gt%3B%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%20%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%20%20869.481128%5D%20remoteproc%20remoteproc0%3A%20powering%20up%20imx-dsp-rproc%0A%5B%20%20869.494189%5D%20remoteproc%20remoteproc0%3A%20Booting%20fw%20image%20rpmsg_lite_str_echo_rtos_imxcm4_m40.elf%2C%20size%20512636%0A%5B%20%20869.544564%5D%20remoteproc%20remoteproc0%3A%20Registered%20carveout%20doesn't%20fit%20da%20request%0A%5B%20%20869.551943%5D%20remoteproc%20remoteproc0%3A%20Failed%20to%20process%20resources%3A%20-12%0A%5B%20%20869.558636%5D%20remoteproc%20remoteproc0%3A%20Boot%20failed%3A%20-12%0A-sh%3A%20echo%3A%20write%20error%3A%20Cannot%20allocate%20memory%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%BB%8F%E5%B8%B8%E5%9C%A8%20uboot%20%E4%B8%AD%E6%98%BE%E7%A4%BA%E7%9A%84%20dts%EF%BC%88u-boot%20%3D%20%26gt%3B%20printenv%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Efdt_file%3Dimx8qm-mek-rpmsg.dtb%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%AE%83%E5%B7%B2%E7%BB%8F%E6%89%93%E5%BC%80%E4%BA%86%20rpmsg%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8qmmek%3A%2Flib%2Ffirmware%23%20uname%20-r%0A5.10.72-lts-5.10.y%2Bga68e31b63f86%0Aroot%40imx8qmmek%3A%2Flib%2Ffirmware%23%20zcat%20%2Fproc%2Fconfig.gz%20%7C%20grep%20-i%20rpmsg%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0ACONFIG_KEYBOARD_RPMSG%3Dy%0ACONFIG_GPIO_IMX_RPMSG%3Dy%0A%23%20CONFIG_REGULATOR_PF1550_RPMSG%20is%20not%20set%0ACONFIG_SND_SOC_FSL_RPMSG%3Dy%0ACONFIG_SND_SOC_IMX_AUDIO_RPMSG%3Dy%0ACONFIG_SND_SOC_IMX_PCM_RPMSG%3Dy%0ACONFIG_SND_SOC_IMX_RPMSG%3Dy%0ACONFIG_SND_SOC_RPMSG_WM8960%3Dy%0ACONFIG_SND_SOC_RPMSG_WM8960_I2C%3Dy%0ACONFIG_SND_SOC_RPMSG_AK4497%3Dy%0ACONFIG_RTC_DRV_IMX_RPMSG%3Dy%0A%23%20CONFIG_CROS_EC_RPMSG%20is%20not%20set%0A%23%20Rpmsg%20drivers%0ACONFIG_RPMSG%3Dy%0ACONFIG_RPMSG_CHAR%3Dy%0ACONFIG_RPMSG_CTRL%3Dy%0ACONFIG_RPMSG_NS%3Dy%0ACONFIG_RPMSG_QCOM_GLINK%3Dy%0ACONFIG_RPMSG_QCOM_GLINK_RPM%3Dy%0ACONFIG_RPMSG_VIRTIO%3Dy%0ACONFIG_HAVE_IMX_RPMSG%3Dy%0ACONFIG_IMX_RPMSG_PINGPONG%3Dm%0ACONFIG_IMX_RPMSG_TTY%3Dm%0A%23%20end%20of%20Rpmsg%20drivers%0ACONFIG_RPMSG_LIFE_CYCLE%3Dy%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1400571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MXRT%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%96%91%E4%BC%BC%E8%BD%AF%E4%BB%B6%E7%BC%BA%E9%99%B7%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bimx8qmmek%5D%5Brpmsg%5D%5Bremoteproc%5D%20remoteproc%20and%20rpmsg%20fail.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B2%A1%E6%9C%89%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%B7%9F%E8%BF%9B%E8%BF%99%E9%A1%B9%E5%8A%9F%E8%83%BD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bimx8qmmek%5D%5Brpmsg%5D%5Bremoteproc%5D%20remoteproc%20and%20rpmsg%20fail.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195089%22%20target%3D%22_blank%22%3E%40WolsYang%3C%2FA%3E%E4%BD%A0%E8%83%BD%E8%A7%A3%E5%86%B3%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E-sh%3A%20echo%3A%20write%20error%3A%20Cannot%20allocate%20memory%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1401590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bimx8qmmek%5D%5Brpmsg%5D%5Bremoteproc%5D%20remoteproc%20and%20rpmsg%20fail.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1401590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%81%E4%BF%AE%E5%A4%8D%E7%BC%BA%E5%A4%B1%20imx_rpmsg_tty%20%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E7%9A%84%E9%94%99%E8%AF%AF%20%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%B0%86%E6%AD%A4%E8%A1%8C%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%82%A8%E7%9A%84%20layer.conf%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EIMAGE_INSTALL_append%20%3D%20%22kernel-modules%22%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E5%BA%94%E8%AF%A5%E8%87%AA%E5%8A%A8%E5%AE%89%E8%A3%85%EF%BC%8C%E4%BD%86%E7%8E%B0%E5%9C%A8%E5%8F%AA%E9%9C%80%E6%B7%BB%E5%8A%A0%E5%8D%B3%E5%8F%AF%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%20%3A%20)%3C%2FP%3E%3CP%3ERemoteproc%20%E4%BB%8D%E5%9C%A8%E4%B8%8B%E9%99%8D%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B0%BD%E5%BF%AB%E5%BE%97%E5%88%B0%E5%A5%BD%E6%B6%88%E6%81%AF%3A(%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
