imx8qm jailhouse
imx8qm jailhouse
Ahelion
Hi all,
Is there any document showing all the steps to have a demo running on imx8qm mek board with jailhouse?
I was going over this: L5.4.70_2.3.3_LINUX_DOCS
but all I could find is a reference to device trees:
Hypervisor Jailhouse Enables the Jailhouse Hypervisor device trees.
• imx8qxp-mek-root.dtb: DTB for root-cell
I do not know what to do with this info. That is why I need a step by step instruction list.
Br, Mircea
Shivu_Guru_24
hi @Ahelion
i am planning to use MCIMX8QM-CPU soc  i need to bringup freertos and Android on top on this do we need hypervisor here,
and also Jailhouse is already present in the latest version of android ?
Ahelion
Waste of time. Nothing works out of the box on nxp imx8qm, at least not with the software provided by nxp. Android does not run in jailhouse, on imx95 they have a small android demo running in xen. freertos can run on the second core m3 core, you can flash the emmc with android and have it like that running. no hypervisor needed.
Rita_Wang
Which version BSP are you want to use?
Shivu_Guru_24
Hi @Rita_Wang
I am using MCIMX8QM soc I need to run android and freertos on top of hypervisor.
Which hypervisor i can use ?
Ahelion
L5.4.70_2.3.3, i was following this quide, so all bsp-s mentioned here I am using.
Rita_Wang
OK, I will help confirm.
Ahelion
any ideea?
Found out that the latest linux kernel does support the lates XEN
How can I get Linux and Android running at the same time?
Rita_Wang
Yes, the xen is supported on the i.MX8QM.
You can refer to the attach document.
Wish you have a nice day
Best Regards
Rita
Shivu_Guru_24
@Rita_Wang Xen willl support on latest kernal 6x?
Rita_Wang
Hi @Shivu_Guru_24 ,
Sorry for late reply. For the XEN the on latest kernal 6x do not support it.
If customer want to use, they can do porting themself. In our BSP 4.14.98 support it. Customer and refer it:
Embedded Linux for i.MX Applications Processors | NXP Semiconductors
Hope this can do help for you
Best Regards
Rita
Shivu_Guru_24
@Rita_Wang i have one more we are buying MCIMX8QM soc
i need to run android and freertos as guest which hypervisor support on this latest kernel?
jailhouse supports on latest kernel for my requirement
Rita_Wang
Hi @Shivu_Guru_24 ,
Jailhouse is a Type 1 hypervisor for i.MX 8. Xen is not support in the latest version BSP.
Best Regards
Rita
Ahelion
I can tell you right now, it is not supported. I could not get jailhouse or xen to work on imx8qm. Whatever documentation i find is referencing linux4.9, which can not be build anymore.
Jerry137207
Hi, Ahelion:
I'm interested in runing multiple OS based on jailhouse, but related information is lack. I've sucessfully run jailhouse test demo in Imx8qm mek board. If you would like share info each other, plz email me: 1372071341@qq.com.
Shivu_Guru_24
@Jerry137207
Are you running jailhouse on top of hw ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1816185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3EIs%20there%20any%20document%20showing%20all%20the%20steps%20to%20have%20a%20demo%20running%20on%20imx8qm%20mek%20board%20with%20jailhouse%3F%3C%2FP%3E%3CP%3EI%20was%20going%20over%20this%3A%20L5.4.70_2.3.3_LINUX_DOCS%3C%2FP%3E%3CP%3Ebut%20all%20I%20could%20find%20is%20a%20reference%20to%20device%20trees%3A%3C%2FP%3E%3CP%3EHypervisor%20Jailhouse%20Enables%20the%20Jailhouse%20Hypervisor%20device%20trees.%3CBR%20%2F%3E%E2%80%A2%20imx8qxp-mek-root.dtb%3A%20DTB%20for%20root-cell%3C%2FP%3E%3CP%3EI%20do%20not%20know%20what%20to%20do%20with%20this%20info.%20That%20is%20why%20I%20need%20a%20step%20by%20step%20instruction%20list.%3C%2FP%3E%3CP%3EBr%2C%20Mircea%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223593%22%20target%3D%22_blank%22%3E%40Jerry137207%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EAre%20you%20running%20jailhouse%20on%20top%20of%20hw%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20using%20MCIMX8QM%20soc%20I%20need%20to%20run%20android%20and%20freertos%20on%20top%20of%20hypervisor.%3C%2FP%3E%3CP%3EWhich%20hypervisor%20i%20can%20use%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWaste%20of%20time.%20Nothing%20works%20out%20of%20the%20box%20on%20nxp%20imx8qm%2C%20at%20least%20not%20with%20the%20software%20provided%20by%20nxp.%20Android%20does%20not%20run%20in%20jailhouse%2C%20on%20imx95%20they%20have%20a%20small%20android%20demo%20running%20in%20xen.%20freertos%20can%20run%20on%20the%20second%20core%20m3%20core%2C%20you%20can%20flash%20the%20emmc%20with%20android%20and%20have%20it%20like%20that%20running.%20no%20hypervisor%20needed.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225423%22%20target%3D%22_blank%22%3E%40Ahelion%3C%2FA%3E%3C%2FP%3E%3CP%3Ei%20am%20planning%20to%20use%26nbsp%3B%3CSTRONG%3EMCIMX8QM-CPU%20%3C%2FSTRONG%3Esoc%26nbsp%3B%20i%20need%20to%20bringup%20freertos%20and%20Android%20on%20top%20on%20this%20do%20we%20need%20hypervisor%20here%2C%3C%2FP%3E%3CP%3Eand%20also%20%3CSTRONG%3EJailhouse%20is%3C%2FSTRONG%3E%26nbsp%3Balready%20present%20in%20the%20latest%20version%20of%20android%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Ahelion%3A%3C%2FP%3E%3CP%3EI'm%20interested%20in%20runing%20multiple%20OS%20based%20on%20jailhouse%2C%20but%20related%20information%20is%20lack.%20I've%20sucessfully%20run%20jailhouse%20test%20demo%20in%20Imx8qm%20mek%20board.%20If%20you%20would%20like%20share%20info%20each%20other%2C%20plz%20email%20me%3A%201372071341%40qq.com.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1825137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1825137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20can%20tell%20you%20right%20now%2C%20it%20is%20not%20supported.%20I%20could%20not%20get%20jailhouse%20or%20xen%20to%20work%20on%20imx8qm.%20Whatever%20documentation%20i%20find%20is%20referencing%20linux4.9%2C%20which%20can%20not%20be%20build%20anymore.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1825130%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1825130%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EYes%2C%20the%20xen%20is%20supported%20on%20the%20i.MX8QM.%3C%2FP%3E%0A%3CP%3EYou%20can%20refer%20to%20the%20attach%20document.%3C%2FP%3E%0A%3CP%3EWish%20you%20have%20a%20nice%20day%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1824117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1824117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eany%20ideea%3F%26nbsp%3B%3C%2FP%3E%3CP%3EFound%20out%20that%20the%20latest%20linux%20kernel%20does%20support%20the%20lates%20XEN%3C%2FP%3E%3CP%3EHow%20can%20I%20get%20Linux%20and%20Android%20running%20at%20the%20same%20time%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1819428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1819428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%2C%20I%20will%20help%20confirm.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1819291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1819291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EL5.4.70_2.3.3%2C%20i%20was%20following%20this%20quide%2C%20so%20all%20bsp-s%20mentioned%20here%20I%20am%20using.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1819245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1819245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhich%20version%20BSP%20are%20you%20want%20to%20use%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2330480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2330480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%26nbsp%3BXen%20willl%20support%20on%20latest%20kernal%206x%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2330554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2330554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%26nbsp%3Bi%20have%20one%20more%20we%20are%20buying%20MCIMX8QM%20soc%26nbsp%3B%3C%2FP%3E%3CP%3Ei%20need%20to%20run%20android%20and%20freertos%20as%20guest%20which%20hypervisor%20support%20on%20this%20latest%20kernel%3F%3C%2FP%3E%3CP%3Ejailhouse%20supports%20on%20latest%20kernel%20for%20my%20requirement%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2330504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2330504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260363%22%20target%3D%22_blank%22%3E%40Shivu_Guru_24%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3ESorry%20for%20late%20reply.%20For%20the%20XEN%20the%26nbsp%3Bon%20latest%20kernal%206x%20do%20not%20support%20it.%3C%2FP%3E%0A%3CP%3EIf%20customer%20want%20to%20use%2C%20they%20can%20do%20porting%20themself.%20In%20our%20BSP%26nbsp%3B%3CSPAN%20data-teams%3D%22true%22%3E4.14.98%20support%20it.%20Customer%20and%20refer%20it%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%3Ftab%3DDesign_Tools_Tab%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEmbedded%20Linux%20for%20i.MX%20Applications%20Processors%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorRita_Wang_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%9B%BE%E5%83%8F.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%9B%BE%E5%83%8F.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%9B%BE%E5%83%8F.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F378953i5960995A32F1E4B2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%9B%BE%E5%83%8F.png%22%20alt%3D%22%E5%9B%BE%E5%83%8F.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EHope%20this%20can%20do%20help%20for%20you%3C%2FP%3E%0A%3CP%3EWish%20you%20have%20a%20nice%20day%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2331123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8qm%20jailhouse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260363%22%20target%3D%22_blank%22%3E%40Shivu_Guru_24%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EJailhouse%20is%20a%20Type%201%20hypervisor%20for%20i.MX%208.%20Xen%20is%20not%20support%20in%20the%20latest%20version%20BSP.%3C%2FP%3E%0A%3CP%3EWish%20you%20have%20a%20nice%20day%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E
