imx8mq android8.1 modified the init.rc,after make bootimage can not apply?
1,759件の閲覧回数
传策薛
Hi,community:
   I add something to the /device/fsl/evk_8mq/init.rc,  and then "make bootimage"(I can see the $OUT/root/init.freescale.rc is changed),   and "fast boot flash boot.img", but when the board up, I found  that the /init.freescale.rc  did not changed, How is that happened?
help me.
1,594件の閲覧回数
diegoadrian
Unfortunately, I do not know if there will be a faster way. But everything points that not. I apologize for the inconveniences.
Diego.
4 返答(返信)
1,594件の閲覧回数
diegoadrian
I apologize for the late answer
Let me verify with my board if this happens.
Furthermore, can you please try building the whole Android GUI again and not only the boot image?
Diego.
1,594件の閲覧回数
传策薛
Dear Diego~:
   Build the whole Android can  apply the changes of “init.rc”, but  if I can just "make bootimage" to apply the "init.rc", that will help my debugs a lot~~~,Can Android8.1 has some faster way to apply "init.rc"  without build the whole Android Source?
1,595件の閲覧回数
diegoadrian
Diego.
1,594件の閲覧回数
传策薛
Thank you same~
