imx8mq+Android9 compile error:"zip error: Zip file structure invalid (out/target/product/evk_8mq/obj/APPS/xxx.apk"
传策薛
Contributor V
Hi community:
When compiling Android9 recently, I often encounter the following error.
(Compile error app is not fixed, sometimes other apk)
ERROR: unable to open 'out/target/product/evk_8mq/obj/APPS/SettingsProvider_intermediates/package.apk' as Zip file for writing
zip error: Zip file structure invalid (out/target/product/evk_8mq/obj/APPS/SettingsProvider_intermediates/package.apk)
What should I do ?
weidong_sun
Hello Mr Xue,
   I'm not sure if your Android source is missing files. I wrote a document on how to download Android 9.0 source code and compile it in China. I did not encounter this problem. You can refer to it.
see the link, please!
https://community.nxp.com/docs/DOC-343242
Have a nice day!
BR,
Weidong
传策薛
Contributor V
