imx8mq+Android2.3.0 adb issue?
4,244 次查看
传策薛
Hi community:
   The current imx8mq Android9_2.3.0 bsp adb function is invalid. The previous bsp function of Android9_1.0.0 is normal. What is the reason?
6 回复数
4,087 次查看
diegoadrian
Are you testing adb with Windows or Linux?
Diego.
4,087 次查看
传策薛
I use the android-adb-tools tool of ubuntu16.04 system, brushed the 2.3.0 and 1.0.0 version of the system package, "1.0.0" system "adb devices" command has devices; but "2.3. 0 "No.
4,087 次查看
diegoadrian
Could you please try setting the following configuration?
To make ADB work under a Linux computer, you need to create a new rule for a plug device.
To make the new rule, create a document inside the /etc/udev/rules.d named 51-android.rules. Inside the document write the following:
SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="d002", MODE="0660",
 GROUP="plugdev", SYMLINK+="android%n"
Where the ATTR{idVendor} and ATTR{idProduct} is the USB id for the board. To know that information. Write lsusb and your Android device is the one named Google Inc.
Then reboot your computer. With this new rule, ADB should work as usual.
Hope this could help you.
Diego.
4,087 次查看
传策薛
I changed dr_mode = "otg" to dr_mode = "peripheral" and it works fine.
Should it still be a kernel driver issue? USB does not work properly in otg mode.
4,087 次查看
diegoadrian
Probably is because of the i.MX8MQ is no longer using a USB OTG. the i.MX8MQ uses USB 3.0.
Diego.
4,087 次查看
传策薛
Ok, THS a lot
