imx8mplus DDR correction
3,496件の閲覧回数
t2865k5
Dear NXP,
I replaced the MT53D512M32D2 SDRAM in the imx8mplus board. Can you help me check the registration configuration in SRG_IMX8_Plus_LPDDR4_RPA_V6.xlsx. Is it correct?
3 返答(返信)
3,467件の閲覧回数
t2865k5
Dear NXP,
It seems to be used on the imx8m mini platform.
I want to use MX8M_Mini_LPDDR4_RPA_v18.xlsx parameter on imx8mplus platform .
Can I use it (MX8M_Mini_LPDDR4_RPA_v18.xlsx) on imx8plus platform ?
3,474件の閲覧回数
t2865k5
Dear NXP,
Thank you for your information.
I have some questions as follows:
How to query from the datasheet?
(1)Number of Channels
(2)Number of Chip Selects used2
(3)Bus Width
(4)Clock Cycle Freq (MHz)3
3,489件の閲覧回数
Hi Albert
such part used on i.MX8M Mini EVK and example can be found on
