imx8mp usb 传输速度配置
imx8mp usb 传输速度配置
gaotao
在imx8mp中怎么将usb根节点控制器(root_hub)的速率由480M切换到12M??
imx8mp-evk.dts中的配置貌似不起作用
&usb_dwc3_0
    maximum-speed = "full-speed";
是需要在驱动中修改寄存器或者改变握手相关代码吗?dwc的问题还是xhci(plat)?
AldoG
the property for the node is ok, but please note that this does apply only if it is working as peripheral, if the i.MX8MP is working as a host, then the negotiation takes care of the speed being used.
Best regards/Saludos,
Aldo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2303307%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Eimx8mp%20usb%20transfer%20speed%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303307%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CSPAN%3EHow%20to%20switch%20the%20rate%20of%20the%20usb%20root_hub%20controller%20(root_hub)%20from%20480M%20to%2012M%20in%20imx8mp%3F%20%3CBR%20%2F%3EThe%20configuration%20in%20imx8mp-evk.dts%20doesn't%20seem%20to%20work%20%3CBR%20%2F%3E%26amp%3B%20usb_dwc3_0%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20maximum-speed%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E%22full-speed%20%22%3C%2FSPAN%3E%3CSPAN%3E%20%3B%20%3CBR%20%2F%3EIs%20it%20necessary%20to%20modify%20the%20registers%20or%20change%20the%20handshake%20related%20code%20in%20the%20driver%3F%20dwc%20problem%20or%20xhci(plat)%3F%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2303307%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20usb%20%E4%BC%A0%E8%BE%93%E9%80%9F%E5%BA%A6%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3Ethe%20property%20for%20the%20node%20is%20ok%2C%20but%20please%20note%20that%20this%20does%20apply%20only%20if%20it%20is%20working%20as%20peripheral%2C%20if%20the%20i.MX8MP%20is%20working%20as%20a%20host%2C%20then%20the%20negotiation%20takes%20care%20of%20the%20speed%20being%20used.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2FSaludos%2C%3CBR%20%2F%3EAldo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
