imx8mm sdcard
imx8mm sdcard
jieh朱
Hello there
The * .sdcard in imx8mm can only be generated by yocto compilation. If I compile dtb, Image and packaged rootfs separately, can I package them into * .sdcard format?
Thank you
joanxie
karangajjar
Senior Contributor II
Hi  jiehuai zhu ,
Yes, .sdcard image is generated by Yocto.  You can look at the file below used in generation of the sdcard image:
sources/meta-fsl-bsp-release/imx/meta-bsp/classes/image_types_fsl.bbclass
You can check the steps used in the above file on how to create the sdcard image.
Karan Gajjar
