imx8m plus HAB
已解决
imx8m plus HAB
跳至解决方案
2,833 次查看
splkwill
I have an imx8m plus device where I would like to enable secure boot for our Yocto image. I'm trying to understand the process here. Currently I am reading AN4581 and have a couple of questions.
For the process outlined in AN4581, does this only sign the output image generated by Yocto, but we would need to extend the root trust to other software components (like Uboot, etc...)
Also, for the SRK table, is there a minimum number of certificates we need to supply? Is three the recommended?
1 解答
2,818 次查看
splkwill
Hi, just reading the application note over again and I got my questions answered.
在原帖中查看解决方案
2 回复数
2,819 次查看
splkwill
2,713 次查看
hrlawrence
I am having the similar requirement to secure the first stage bootloader, u-boot and linux kernel with the yocto build could you please share the required documents
Lawrence
